Ah, but if I get the m10 then the a8, all my 26650 lights will have 26650 cells in two deliveries. :bigsmile:
Well, I bid on an m10 with two cells and charger from cyberport888. We shall see. :bigsmile: I’ll go for the a8 next, its just the spare 26650 has a home already on the way…
Well, £26.80, its paid for, I’d guess I’ll have it before our caravan holiday on the fourth of august :bigsmile:
Got one… But mine is a Skyray M10 …. I guess they are all the same …… Bright as hell….
there are a lot of light on ebay,are so beautiful.i think the quality is also good.lol
Yes… We need to buy them all… |( … I love torches …
G’day astodut, welcome to BLF. Good choice on the M10, its a great light.
Welcome to the addiction, astodut!
What a warm welcome….thank you.
I need 26650 batteries, anyone know which one is the best for M10?
I love my M10. Great beam, very white light and hardly any noticeable rings.
But when I opened the top, I found that mine had a U2 rather than a T6 led as specified. I actually prefer the U2 for this type of thrower light because it’s brighter and throws further.
I am just wondering if others who bgt this light also receive a U2-led light? Reason i am asking is because i am thinking of getting a second M10 and wondering if i need to go back to the same seller to get an U2-led or if any seller would do (since the seller quoted by astodut is quite a bit cheaper).
I don’t like bezel so I finished with sand paper ( 1 hour )
Left >> TrustFire A8 3040mA + XM-L U2
Middle >> POK 3040mA + XM-L T6 3C
Right >>> KeyGos M10 3040mA + XM-L U2
These pics make me wanna buy them again……
It’s certainly not conclusive but the star had a label - see below photo:
To be sure, the Keygos M10 is whiter/brighter than any of my 4 other XM-L lights - all of which are supposedly T6. In any case, the Keygos manufacturer wont have any reason to fake the label since the light is advertised as a T6 anyway.
BTW, did others have the same label as mine? Seems like Pok has also classified his M10 as a U2
Nope, mine come with the star alu like your pic but wrote only “XML” (your pic wrote “XML-U2”)
I change to XM-L U2 from fancyflashlights.
I have just ordered the Keygos M10. Can someone confirm that the TrustFire Protected 18650 will fit this flashlight.
This is the battery I want to order:
It should do, but why not order with the keygos cells? They seem pretty good to me.
I hope m10’s do start coming with xm-l u2 emitters, I’ll be ordering another if so.
Welcome to the cool kids' club, carlo_light!
Hey Everyone. Just spent about 8 hours of my Sunday reading though the various posts on this forum. I must say I’m impressed with the info available here.
I just got a TechLite Lumen Master 200 from a friend. I realize this little guy is a $7 flashlight from a 3 pack but I really liked it. I use the word liked because the driver broke as I was trying to modify it to fit an 18650. (I broke a trace trying to remove the metal contacts that connect to the case. It was late :~ )
Because I am so cheap, and actually enjoy trying to get something great for less I am looking at the Keygos M10. I figure that with the way these lights are going that getting into a 26650 to begin with isn’t a bad thing. Because it also accepts 18650s I can be frugal and pull those out of laptop batteries if I need to.
It is important to me that I get a light that tail-stands. I live in Central Asia and am often without power. This light will serve to light up a room for me just about as much as anything. That is why I steered away from the Balder SE-2, which was looking very promising.
I’ve looked around everywhere and can’t find any info on how many lumens this light has for high, medium, and low. Does this light have memory? Can I go straight to low if that is what I was using last? Also, I can’t find any run times for either an 18650 or a 26650 at any of those settings. I’m honestly more interested in knowing the run times for the lower settings since that is what I would probably be using for long duration uses.
Also, if you have any suggestions for something else that I should consider for a first and only light then please let me know.
I’d appreciate any help you can give a new guy.
I can’t give you lumen ratings or exact run times, but my m10 on low will give adequate illumination for a long time on the supplied keygos cells. I also have a couple of inr 4000mah cells that it seems to like. Yes it tailstands, with the very good lanyard fitted. I can’t recommend this light enough.
