The BLF Battery Data Base
Link please , to the batteries on DX ... thank you ,
http://www.dealextreme.com/p/maxuss-ni-mh-aaa-1-2v-1250mah-batteries-4-pack-10730 These ?
Same company I think. Though I think mine were posted in the UK - they certainly arrived much faster than most HK stuff
Hi All,
First post here.
More capacity data on these Vapex AAA 950 mAh LSD. (Already tested by old4570). Sourced from ebay.
Out of packet (0.5A disch):
1) 128 mAh
2) 372 mAh
3) 0 mAh
4) 762 mAh
Charge/Discharge at .5A
1) 869 mAh (91.47%)
2) 910 mAh (95.79%)
3) 861 mAh (90.63%)
4) 868 mAh (91.37%)
Measurements from Maha c9000 (6mths old)
So broadly in line with old4570 results.
I wouldn't want to rely on these straight out of the packet!
I am interested to see if they have poor LSD or if the original prepacking charge is the cause of the wild differences in capacity out of the packet.
I enjoy the site.
Cheers,
Tim
WElcome sirnic!
Good to have you here!
Glad to have you here, Sirnic. Way to jump in and contribute!
Aloha and welcome to BLF Sirnic!
Thats it!
I also tested the AA Maxuss 3000 mah batteries. About 1750 mah. But I had recharged them 2 times so they are not new. Don't buy them http://www.dealextreme.com/p/maxuss-1-2v-3000mah-ni-mh-aa-rechargeable-batteries-2-pack-7729
I got an 8 pack of eneloops from an OZ seller. Came in a clear packet- no label or anything. They look legit as far as I can tell. Currently discharging straight out of the packet.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=120682137785&ssPageName=STRK:MEWNX:IT
AA Eneloop
Straight out of the packet
1. 1367
2. 1376
3. 1352
4. 1370
Discharge on maha c9000 at 1000 mah.
I will now charge/ discharge.
Charged up to
1. 1843
2. 1939
3. 1979
4. 1939
True results wont be known until discharge occurs in about 4 hours.(2 hrs rest - 2 hours discharge approx)
Definately legit batteries code is 10- 08 ? Hard to read though
Discharge results
1. 1887
2. 1931
3. 1910
4. 1889
2 times is ok ...
Maxuss AA 3000 mah from DX
Tested 3 so far. 2 cycles
1. 1750
2. 1731
3. 1800
Maha c 9000
Button top
Length 50 mm
diameter approx 14mm. sorry dont have a digital caliper
Very poor performance against claimed capacity. I wonder if they are re badged 2400 or 2000 or are they equally poor performers.
I have some ready to use Varta aa 2100 and 2500. I will not post results as they are not new and have been "cooked" a few times on the 15 minute charger. I noted that the 2100 has been charging for almost 3 hours and the capacity was 2400 mah and climbing. The battery felt overly hot so I stopped it charging. I'll buy a new pack and test soon.
Arrived today : Matsushima AAA LSD [ 80% after 1 year ]
Capacity claim 750mAh min to 800mAh
Will start these ASAP
Discharged straight from the packet :
Cell 1 / 461mAh
Cell 2/ 0mAh
Cell 3/ 429mAh
Cell 4/ 428mAh
Charged and discharged
Cell1/ 679mAh
Cell2/ 692mAh
Cell3/ 702mAh
Cell4/ 714mAh
Just got a pack of Trustfire grey 16340 protected. I'll try to find a way to asses their capacity to contribute to the list.
Soshine 1100mAh Ni-MH Rechargeable AAA Batteries with Case (4-Battery Pack) from http://www.dealextreme.com/p/26987 ($6 shipped), non LSD
La Crosse BC-900 charger. Brand new cells.
Charger Test mode results: 1022 1007 1035 1050 ma (charge 500 ma, discharge/measure capacity at 200 ma, recharge at 500 ma, cool down)
2nd cycle 500 ma Discharge mode results: 1050 1066 1078 1096
I think these are pretty good numbers for inexpensive AAA cells, and they are nicely consistent across the 4 cells. They also get good reviews on DX. They arrived almost 100% discharged.
Some Pisen AAA's arrived a short while ago , also some 18650's [ Sanyo - Samsung ]
http://www.dealextreme.com/p/pisen-hr11-45-1-2v-800mah-ni-mh-rechargeable-aaa-batteries-2-pack-18316
Well , look nothing like the picture .. 800mAh capacity claim , Pre charged claim , and low self discharge claim , Since its in Chinese ???
Will discharge first , then charge and re-discharge from being fully charged .
Out of the Packet : Discharged @ 500mAh
1/ 680mAh
2/ 688mAh
Ok charged them up , and then discharged again at 0.5A
1/ 793mAh
2/ 804mAh
Those are pretty decent numbers but who knows how they'll hold up over time.
Just got this one in , Sanyo 2600mAh capacity .. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370406814898&ssPageName=STRK:MEWNX:IT#ht_2220wt_905
Discharged at 0.5A to 3v .. Now some manufacturers say you can discharge to 2.75 or 2.5 Volts under load ..
Anyhow , the hobby charger stops at 3v under load = 2433mAh to 3v ..
Being Sanyo there is no protection circuit ..
http://cgi.ebay.com/Samsung-18650-ICR18650-28A-2800-Li-ion-3-7v-Battery-x2-/370422727802?pt=US_Batteries&hash=item563eea447a#ht_2260wt_905
Discharge Termination Voltage: 2.75V
Capacity: 2800mAh (Min 2750mAh)
Well , after charging to 4.2v , and then discharging to 3v under load [ 0.5A ] I got some 2486mAh ...
If I were able to discharge lower it may have come close [ may have ] to the claimed minimum .
So keep in mind that discharge is between 4.2v and 3v ..
Thanks again for all the work you're doing collecting data on these batteries, Old4570!
