200lm from an NiMH if not an alkaline ought to be doable now. Closest I have is the EastwardYJ J09 at around 165. The more recent ones with XP-G's ought to do this.
If I needed a light at work, I'd be issued with one. Which is not about to happen. And is also why there are about 18 of them in my work bag. OK two of them are being posted in the morning.
The UI on the Zebras is about as perfect as it gets with fixed modes. 6 modes - all brightnesses but no strobes. Highest high and lowest low on this planet on AAs. Every mode accessible from "light off"-status.
How good are you at removing threadlock and unsoldering/resoldering wires. Ive taken the head apart on mine with extreme difficulty and damage, but managed to put in a R4 4C tint XP-G and its soo pretty now. Still too doughnutty for me, but the output on RCR is crazy, feels like its doubled over a normal 130 from AA.
The past week I've found myself drooling over the Nitecore D11. To me, it is perfection in design. Just a gorgeous light. The other light I've been eyeing up is the Fenix TK-35 :)
If I pay that much for a light, I want it to be the light I want, not a host for modding. At least that's what I say now. I don't think Sunwayman will ever have a neutral light. There aren't many companies that do neutrals and they mostly do it in communication with CPF people. Since Sunwayman doesn't communicate, I doubt they'd do neutrals. The only possibility would be if some of their retailers push for it (assuming they are communicating with them). It doesn't seem that hard to me: order some neutrals and one day instead of installing the regular LED's at the factory, just do the neutrals. Make 100 or 200 and see how they do.
Sunwayman M20C. Clean, attractive design and very compact for 18650 flashlight with selector ring (almost the same size as WF-501B). Even not so expensive ($66 at Solarforce Store).
I would love to have a Zebralight SC51 because I don't have anything like it.........yet. From all the reviews about it, you just can't go wrong.
I would also love to have a Fenix TK45 but since I already have the TK40 it just doesn't make sense but I'd still love to have one. It just looks so different and very cool. Another thing I love about them is because they use 8*AA only because I have tons and tons of AA's.
I do want a whole lot more but I'll stick with these for now.
Between the nitecore D-11 and the sc51.Zebra Light Perfect uable modes not a two handed ring spinning act .I don't know about the jetbeams but The ones i've played with are a pain . I want to like the sunwayman but messing with a ring is awkward Holding down a button ramping between my own pre-selected modes is as about as good as it comes.I like a side button light or a tail button ...the Klarus seems to be a hybrid between both .I just don't know anything about them .
To me it's about feel in your hand , tint , beam quality ,and user friendly interface .
The nice thing about a ring is you can set it to the level you want before you turn it on. In that sense, the Sunwayman M10A is preferable because it has stops for the modes and you could count them. But I think the Low wasn't that low or something. With a ring, 4 stops ought to do it: very low, low, medium, high.
Wow, am I glad this thread came up. My birthday's coming up and I'm getting a TK35. I'll try to do my best rookie write up on it but it may be a while since I still haven't ordered any batteries from DX yet. This will be the most expensive light I've ever owned. I'm getting it for $109 on Amazon I believe.
Ok, so here's my question. If someone let you choose between an Eagletac M3C4 or a Sunwayman M60R, which one would you pick and why? Which one has more throw? Which one has more flood?
I haven't seen either one in person so share your thoughts.
I might go with the Eagletac because it comes with a XM-L (one version anyway; there are about six different versions of the M3C4) which should give you the best bang for your buck: literally because the LED is cheaper than a SST-50, but also because it is more efficient, though maybe not quite as bright as a SST. Also, with only 2 18650's it should be lighter weight than the M60R. The Sunwayman is probably better made, but I have no experience with either light. Also I can't compare beams, though there are reviews out there of both, including selfbuilt's review that compares the M60R and M3C4 SST, showing better throw for the Eagletac and a slightly larger reflector.
brted, thanks for the link. I'll check it out when the site comes back up. Yes, I was referring to the XM-L version of the Eagletac. A picture of the beamshots would help me out so thanks for the link!
The variable ring on the V10R is great. The low is low enough that I don't bother with the switch, just keep it on low. I can barely see the hotspot beyond a couple meters with night adjusted eyes, and I can look into the emitter even at night. Only thing is the runtime on low is at best a day. The stepped M10A/R has a low that is about 2 lumens comparing against a D10. Mode spacing is very nice on the M10A/R.
Only thing I dont lke about rings = resistance to dust/sand. Its perfectly waterproof and dust proof, but just the idea of getting sand stuck in a ring that turns and scrapes is not fun. Maybe its not really a problem, but I still get that feeling.
THe M60R is not a real thrower, its got a beam thats really broad. The beam is SUPER smooth however, with a perfectly uniform wide flood, with a very uniform wideish hotspot. Its a GREAT general purpose light with well spaced levels. Low could be lower (lows can ALWAYS be lower... hahaha) but otherwise its nice. Very blue tint, as is with most sunwayman lights, tints are very average. The V10R comes with a greenish tint.
