actually this one. The v2 nanjgs use 380ma chips and have nicer mode spacing and come in 4, 6 & 8 chip versions. KD isn’t the only place that sells them though they were the first.
PWM
Pulse Width Modulation. A technique of varying the brightness of a LED by flashing it on and off very quickly, making it appear to the eye that the LED is dimmer. Good PWM is at such a high rate that you can’t notice it. But if you wave your hand in front of the light and get a strobe effect, the PWM is getting too low. Some use current regulation which makes the light dimmer without PWM and is also more efficient.
Here is a link that you might find useful that has some of the words and stuff related to flashlight stuff
Built on the revolutionary SC³ Technology Platform, the XP-G2 LEDs combine high light output, reliability and efficacy to deliver up to 151 lumens per watt at 350 mA, 85°C or 165 lumens per watt at 350mA, 25°C in cool white (both at 6000K). In warm white (3000K), the XP-G2 LED delivers up to 133 lumens per watt at 350 mA, 85°C or 145 lumens per watt at 350mA, 25°C. The SC³ Technology Platform leverages Cree’s advanced silicon carbide technology, features advancements in LED chip architecture and phosphor and showcases a new package design to deliver the most advanced lighting- class LED components in the industry.
The problem with PWM is that it drives to led to HI then Off. On High, the led is less efficient than at a lower current level. Just because it is off for a small period of time does not mean the average brightness, as seen by user, is not lowered. I believe the bottom line in the CPF forum was that PWM is NOT the most efficient approach, because of this principle. I am wondering why this technology persists in drivers?
2.8A is already high enough for a small 18650 flashlight and just a bit higher will not have any visible difference.
The PWM frequency is high so there is no visible PWM.
