If money were no object. If only!
What about new Klarus Light?
I like the Klarus UI. Haven't heard many reviews on those though.
The new Lumintop TerminatorX is a beautifully-made flashlight that puts out a ton of light. At just under US$100, it's the one for me .
I should know, I have one (hee hee ). Out of about 20+ lights I have owned (many given away/sold off already), it's my favourite... so far.
Feel free to rant away Don.
Like a lot of others top of my list is the TK-35, I'm sure if money were no object I'd manage to think of some others :P
Between the nitecore D-11 and the sc51.Zebra Light Perfect uable modes not a two handed ring spinning act .I don't know about the jetbeams but The ones i've played with are a pain . I want to like the sunwayman but messing with a ring is awkward Holding down a button ramping between my own pre-selected modes is as about as good as it comes.I like a side button light or a tail button ...the Klarus seems to be a hybrid between both .I just don't know anything about them .
To me it's about feel in your hand , tint , beam quality ,and user friendly interface .
The nice thing about a ring is you can set it to the level you want before you turn it on. In that sense, the Sunwayman M10A is preferable because it has stops for the modes and you could count them. But I think the Low wasn't that low or something. With a ring, 4 stops ought to do it: very low, low, medium, high.
Wow, am I glad this thread came up. My birthday's coming up and I'm getting a TK35. I'll try to do my best rookie write up on it but it may be a while since I still haven't ordered any batteries from DX yet. This will be the most expensive light I've ever owned. I'm getting it for $109 on Amazon I believe.
Ok, so here's my question. If someone let you choose between an Eagletac M3C4 or a Sunwayman M60R, which one would you pick and why? Which one has more throw? Which one has more flood?
I haven't seen either one in person so share your thoughts.
I might go with the Eagletac because it comes with a XM-L (one version anyway; there are about six different versions of the M3C4) which should give you the best bang for your buck: literally because the LED is cheaper than a SST-50, but also because it is more efficient, though maybe not quite as bright as a SST. Also, with only 2 18650's it should be lighter weight than the M60R. The Sunwayman is probably better made, but I have no experience with either light. Also I can't compare beams, though there are reviews out there of both, including selfbuilt's review that compares the M60R and M3C4 SST, showing better throw for the Eagletac and a slightly larger reflector.
http://www.candlepowerforums.com/vb/showthread.php?t=305749&page=1.
brted, thanks for the link. I'll check it out when the site comes back up. Yes, I was referring to the XM-L version of the Eagletac. A picture of the beamshots would help me out so thanks for the link!
Notice a lot of these lights have selector rings. I agree, I want something with a selector ring.
Good god! Don't waste your time with DX... go to Lighthound right in Texas and get real batteries-in 1-2 days instead of decades!
Rich
The variable ring on the V10R is great. The low is low enough that I don't bother with the switch, just keep it on low. I can barely see the hotspot beyond a couple meters with night adjusted eyes, and I can look into the emitter even at night. Only thing is the runtime on low is at best a day. The stepped M10A/R has a low that is about 2 lumens comparing against a D10. Mode spacing is very nice on the M10A/R.
Only thing I dont lke about rings = resistance to dust/sand. Its perfectly waterproof and dust proof, but just the idea of getting sand stuck in a ring that turns and scrapes is not fun. Maybe its not really a problem, but I still get that feeling.
THe M60R is not a real thrower, its got a beam thats really broad. The beam is SUPER smooth however, with a perfectly uniform wide flood, with a very uniform wideish hotspot. Its a GREAT general purpose light with well spaced levels. Low could be lower (lows can ALWAYS be lower... hahaha) but otherwise its nice. Very blue tint, as is with most sunwayman lights, tints are very average. The V10R comes with a greenish tint.
I wonder if a motion control mechanism (like in Maglite XL100) would work more reliably.
Here in Turkey, I fill my petrol running Passat's fuel tank (~66lt) for $170, so a $100 is just a half tank, and a good buy :)
I'd love to have a Zebralight btw.
I believe the maglite XL-100 is fully hidden inside, so I wouldnt be as concerned about being thrown into the sand. However I dont see a tilting UI working too well in the dark if you need to read which way is up? I dont have one, I dont know...
If there is one light way out of budget range that appeals me is the TK-35.
Ow! That is expensive.
My tank is only 53l which helps.
Whats the price of fuel per litre. Apparently half of that is meant to be taxes already.
Petrol here is between $1.3 to 1.4 per L
Diesel is $1.4-1.6 per L
Petrol is $2.50 per L, well actually it is $0.76 in real plus the taxes :)
Diesel is $2.00 per L
Petrol is up to $2.10/litre in the cities - more outside them. I can usually get it for around $2.05.
Diesel is more - can't remember how much more.
