Hi guys, I am in a bit of a pickle once again. I have ordered the wrong size boards from Cutter (should have gotten the 20mm rather then 10mm)
I am after 16mm boards (for p60’s) for XP-G, XT-E and XP-E LEDs. If you know of anywhere that sells these for less then $0.5 each including postage please stick a link up… I have searched high and low but the only places I can find are illumination supplies ($0.5 + postage which will probably mean they end up being $1 per board) and a chinese seller on AliExpress who only sells lots of 100-500 ($0.2 each though including postage however I don’t need 100 of them, only about 20: anyone want to go 1/5ths?).
Any help hugely appreciated!
Side thought:
Darn it my Solarforce clicky just broke!
Looks like there are quite a few 16mm XML boards available quite cheaply: does anyone know if they are compatible with the smaller XP and XT footprints?
Found these as well: This product is no longer available. so have sent a inquiry (I wonder if the supplier: KD means KaiDomain? (ironically I Googled XML boards and these came up).
