Sorry to bring up this old thread. But are you guys saying that they don't have UR18650FM stamped on them anymore? I ask because I have just received mine from kaidomain and they just say SANYO R1122.
I think it’s hard to find the exact capacity of the battery .And many times even you buy a battery which told you with 3000mAh ,actually it may only have 2500 mAh ,some even may be 1000mAh .You can just compare this battery with a standard battery.For example ,you have one standard 2000mAh battery ,you can try to charge that with the same charger.Just see the time which takes for the two battery to be full .And then you can use them in the same flashlights to see the runtime for each battery. This is just my method,you can have a try
is there a website which can find out what battery it is if u type in some codes off the battery ? i heard google does that but cant find any info on these ones.
I will revive this topic as some very good info about identifying 18650’s was posted for Sanyo and Sony. I just opened 3 HP laptop battery packs and found one with Sony’s (all 6 constant at 3.84V) and two with Samsung ICR 18650 24B (huge difference for all 12, had to scrap 6 of them which were below 2.5V). As I already identified the Sony production date, I was curious if anybody knows about the Samsung codification - on my batteries there is SDI 544.
Any help is highly appreciated.
One on top is easy, LG 2200mAh. Got 12 of those from a very lightly used pack, work good.
The red one: printed FDMPT2 & a serial number, and either an A or B printed on the other side. Printing is on the cell body with transparent heatshrink, white insulator ring. I got a TON of those from old IBM packs, supposedly they were 'manufacturer reconditioned', but all cells were D-E-A-D when pulled... and revived when stuck in a cheapie 2-bay charger with a good cell, and then took a charge normally, and hold good voltage after and work just OK when load tested, but nothing spectacular.
And the bottom one... HOLY COW. I don't have a clue what it is, but they are monsters. Came from a virtually new aftermarket replacement pack, but it was only a 6-cell. ;[
I don't have a hobby charger or anything to properly check capacity, so here's what I did... all cells fully charged, stuck in a generic 501b/XM-L T6. Checked start voltage, tailcap amps on HI, tailcap amps on LO. Ran each one 70 minutes on LO, and rechecked volts & amps.
You guys are utterly crazy … and know what i count me in too
This battery-pulling is highly infectious. I got an old laptop-battery from a Thinkpad and pulled it open.
The battery was good for about a minute or so in the laptop then it shut down.
I found 6 green cells (SF US18650GR T6A) in it that i just could identify (thanks to this thread) as Sony 2200mAh.
Now to the strange part
I measured them with my DMM and got 4.16V from every cells of the pack.
Hmm… No bad cell ??? I tested them in my EDC (1x18650 ~2.5A) for a few seconds and it worked well
I just learned that waiting a week or so and measuring them again would give me more info.
Is it possible to measure the internal resistance with an DMM?
As i understand a DMM aplies voltage through a measured part to determine resistance
so it should give odd values or am i wrong?
You should be able to calculate the internal resistance for a cell as it discharges, it will probably increase as the cell is discharging. But at any given point it should be the delta V / delta I
(open circuit voltage minus under-load voltage then divide this difference by the load current)
If the open circuit voltage is 4.2 and it drops to 3.8 while drawing 1 amp then the internal resistance would be 4.2 minus 3.8 which equals 0.4V. Divide 0.4V by 1 amp to get 0.4 Ohms internal resistance.
