Now that it's dark, I decided to get some longer beamshots outside. I took them in my usual spot where these beamshots were. The shed in these shots is believed to be between 150 to 200 feet away. The flashlights are set on the fencepost you see the shadow of. 4AAA NiMh again and camera on manual, same settings for each (the 4AAA ones only).
First, Low:
Medium:
High:
For comparison, Here's a shot of my KD C8 (LOP, 3.0A high) taken earlier this year:
Now that I compare them, I think this UltraOK 4AAA has a tint that is closer to neutral.
Mouseover with the KD C8 (mouse out = UltraOK 4AAA, mouse over = KD C8):
More details on "pill" area: Width of opening is 22.6mm and depth to driver is +/- 16.3mm. I'm wondering now about round Aluminum (or copper) bar. I know there was some company posted awhile ago that sells many different types of metal bars, rods, etc . . . They were in the north central US (Chicago or Detroit?). I'll have to do some more searching. Not sure if my local Lowes or Home Depot carries a close width or not (although if I could get 3/4" aluminum, I could put it inside of 3/4" copper plumbing pipe).
EDIT: Found it - Speedy Metals in Wisconson, Illinois, and Michigan.
Oh, and I don't notice rings at all in the beam of mine! Nice transition from hotspot to spill.
Nice review Garry, I just ordered one of these for $18.99 shipped. From reading the reports on this, and I always get double good lights, I should have ordered two.
cehowardGS, you read about the heatsinking issue? They will need some sort of attention, at least thermal compound to the edge of the star. Mine on 4AAA NiMH drew 2.80A which I think is too much for more than a minute or so without filling the hollow pill. Of course I don't know how long the batteries will hold 2.80A. My Rayovac's are only 650mAh. I'm not sure how the 4h cell (extra voltage) plays in, but if you just divide 650mAh by 2800mA you get 14 mins of runtime at 2.80A! I believe a few posts back it was stated that the light runs 60 to 90 minutes on the AAA's (I think that was on alkalines). Not sure what cells you were going to run this one (26650, 18650, AAA's).
Got my quote from Speedy Metals -> (3) 4" pieces of 15/16" 6061-T6511 aluminum is $6.46 + $5.15 USPS (small flat rate box) for a total of $11.61. That gives me 12" total for use on other future projects. I had them cut it for easier USPS shipping. Not sure yet if I want to go this route or see what I can do with copper plumbing parts.
I went to the local ACE in town and could not find anything that fit snug. Bought some 3/4” copper pipe and it is too small and the 3/4” caps are to big. I am not very good at custome stuff so I tried to wrap the pipe with some aluminum foil and that didnt work either it just wanted to slide out. When I reassembled the light i put some fujik on the outer edges and then me and the kids went outside and tourchered the neighborhood (JK). I ran it on high probably like 10 minutes and it started to warm up after a couple of minutes. I am sure that it was doing better on pulling the heat out but figured it would get alot warmer with a solid insert! Its still nice but thinking of gifting it to someone!
With my low modding skills I decided to order the HD2010 when I read about the 30% off at MeritLine and only paid $25 and some changed shipped so that I could forget about the mod that my skilset/tool set didnt get completed.
So a 3/4" copper pipe won't fit . . .hmmm. . . I was hoping it would. I didn't check an exact fit because I didn't want to unsolder the wires to get full access to the "pill". It looked very close though. I don't know if a thick layer of Fujik would be enough or not. So was the aluminum foil too thin? Loose fit? I have copper foil which is thick and that might work, but still not as good as machining a piece of solid aluminum. Are you up to grinding/sanding/filing a piece of 15/16" aluminum to fit if I sent you a piece? (That is, if I go ahead and decide to order it.)
If you want rid of it I'm interested in obtaining another one.
I wrapped the foil around it twice i think and when i would try to slide it in it would start pushing the foil up. I didnt try real hard to get it in there but now after thinking about it with more force probably would work (definately better then nothing). was trying to solder a top piece on but all I had was a solering iron so i couldnt make it stick to where I needed it so I just gave up. Definately could be interested in a piece of aluminum to put in there. Will definately try that foil thing again after i get something that put a top on a piece of pipe.
Also cant remember what size the driver was so that when I get a better heatsink/pill I could pour some amps to it and see what it can really do!
Thanks
EDITED! - Maybe this would be a good reason to get a dremel!!! Always been wanting one!
Garry, I only got one of these lights and that was for $18.99 shipped. Not going overboard. I am like somebody else that posted here, and they went for the 2010 which is on sale for $25. I like the looks of this light, and the reviews are going 50/50. Most likely I will be runnng this light with 26650/18650. My night time runtimes almost never exceed half hour. I think will be okay.
When you all do mod this light with the better heatsink, post up some pictures. I might be able to get into it.
was think about this on the way home from work. Thought that the hole could be drilled out so that the rod would kind of like press fit right in. Wouldnt have to worry about the lip for the led star as you could install another smalled led star if needed and then it would have more then enough mass. The hard part/expensive part might be the price of the drill bit especially since its kinda like singe use then! Gary I guess you or I could ship the bit to who wanted to use it for a small fee…lol
I received mine today. What i don’t like: strange reflector, not so uniform beam profile, works only with spacer with unprotected cells, press fit tailcap, high resistance springs + wires, hole under the star, crazy pwm in low mode.
what I like: it’s a good looking light, 26650 capability, very cheap, I can say worth the money ($17-18 but not more).
some photos
filled hole, replaced wires
(just a note, the stock wires between the led and the driver has 40 milliohm/ piece, that’s unbelievable high)
improved switch/tailcap, springs
The tailcap current was somewhere around 2.5-2.6A in factory state with a fully charged good sanyo cell. After the modifications 4A with the same cell, that means 800+ otf lumen. The improvement of the candela value: stock: 23-25kcd, modified 35kcd.
definitely not a killer thrower…
Wow nice shots 2X better then mine… But man I got gypt too. My lens well how shall I explain this. About 1/2 of the diameter of the lens
there’s these rainbowy effect. Maybe imperfect glass lens is causing this dimming effect 2/3s the way out. It’s not the outer bezel that’s causing it but I think it’s the lens. Also the last millimeters of the reflector there is 2 distinct BENDs! or cutoff that is CREATING some spot adnormalitities. Why would they ruin a prefectly good reflector by making this abrupt corners that bend back in? Shouldn’t a reflector be smooth and not have corners? What it feels like is a souped up Maglite. Instead of a solid spread then a fallout of XM-L lights. I have 3 of them (C8, 3T6 & J12).
I took the reflector off and wow… more uniform beam & has like 100+ degree good solid spread. I suggest other owners to try this if you have the same problem. It also has a tinge of yellow around the ends? Non-T6?
Anyways 26650 bearly fits. If you have any fat ones… they will be chipping each time they go in due to the screw interior of the tube. My skinny Tenergy 26650 was the slimmest, so it got in much better then the others (Flames/Ultrafire). Also the inside of the tube is bored out like a screw like the other parts or something they didn’t bother sanding it o something so I wish they did. Probably I can do it myself but bah that’s two negative ascepts I have for this already.
The grease or lube that came with my flashlight is a bit tangy, sort of like the organic type I get with my cheap 20 dollar ebay swords that leave your hand smelly after touching it.
And lastly my spring on my flashlight fell off it’s held by a tiny bit of solder. I was trying to err stretch the springs a bit for these other 26650 and it came off. Honestly this flashflight will probably kill TopofKing and I’ll never buy from him again.
In conclusion I think I need to buy a UCL lens or something to fix this issue or cut the reflector 2-5mm short to erase that cornering effect that is killing this light. I was amaze u guys say it’s the reflector? I’ll try to redo the solder and see what you guys did to fix this problem.
I thought about it, but was afraid of the extra voltage (the 4th cell adds). I'm not sure how the LED handles the extra voltage. I assume a direct-drive driver (like in this 4AAA light and the HD2010) does nothing to "buck" extra voltage. Besides, my HD2010 is now apparently dead.
