Multimode 1xAA OSRAM light
3 posts / 0 new
sb56637
sb56637's picture
Last seen: 13 hours 32 min ago
Hello everyone,
I'm looking for a multimode 1xAA OSRAM light.  I currently have the Uniquefire AA-S1, which produces a very beautiful beam, but it's too bright.  What do you think about the Ultrafire RL-168?
http://www.kaidomain.com/ProductDetails.aspx?ProductId=9617
http://www.bestofferbuy.com/ultrafire-rl168-haiii-osram-luww5am-2mode-15...
http://cgi.ebay.com/UltraFire-2-Mode-280-Lums-CREE-OSRAM-LED-AA-Torch-RL...
It's either two modes or 6 modes depending on which site you find it on.  It looks very high quality.  Price varies greatly between $23 and $40.  I suspect the BestOfferBuy item is sold out, since it's no longer in stock at DX.  Any other 1xAA OSRAM multimode lights that you know of?
Thanks a lot!
Don
Don's picture
Last seen: 2 years 1 month ago
All the RL series Ultrafires use Osram LEDs. There just aren't all that many models of it. It should be possible to stick a resistor in the AA-S1 to tame the current a bit and drop the output. Will have a look at the tailcap of mine and see if I can modify it for lower output and longer runtime. With more than 2A from the cell, this one is going to kill alkalines in short order - I'd expect 35-45 minutes depending on when the driver decides it has had enough.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
sb56637
sb56637's picture
Ideally for me, multimode is the way to go.  Frequently I do need high output for a few seconds or minutes, after which I switch it back down to the lowest mode.  I wish they made more multimode OSRAM lights, especially in my preferred 1xAA configuration.
