No, but after 5 minutes is Luke warm on 2 cells. On 4 cells 5 minutes it’s hot …… Hot
I work security so i would need a holster I am working with a tk35 Which has one but u would want shake things up a little lol. So dose it have one or where would I be able to pick one up?
LOL,
thanks raccoon city, very graphic.
I have used the Fandyfire version for a “blue hour photoshoot” at the Fly-in.
Once i had set it up, many other photographers were also taking pictures :bigsmile: :
T 28 Trojan:
SV-4B
I have used a rimmed stainless steel cap with a thin disk magnet placed underneath it and the 4 x 18650 tops for protecting the gold plated driver printed circuit board from grinding when closing the thread. Please refer to Redirecting... album photos.
http://img841.imageshack.us/img841/8701/sscap1.jpg
!http://img841.imageshack.us/img841/8701/sscap1.jpg !
I use an M-4 double mag pouch for my King. Perfect size for it.
Thanks for stopping by, fatlokwok!
Wow. That’s a really nice use for this giant mini floodlight.
I gotta say. I finally pull the trigger n ordered a set from Kaidomain.
Just a question guys.
Is it ok to mix 2 kinds of unprotected batteries? 2600 mAh Sony x 2 and 2600 mAh Samsung x 2?
Thanks…
Sooo, someone made a new driver (Hi - Mid1 - Mid2 - Lo + mode memory) for this flashlight?
LOL!
Super nice work there Edoram - and welcome to BLF :-)
What do you even call such a machine?? Multi copter?
Wonderful use of both things. I am surprised it can lift the flashlight. I would love to see one of those in real life one day.
Thanks for sharing this :-)
I use a Voodoo 40mm grenade pouch, and much like JohnnyMac’s double M4 pouch, it fits perfectly.
That is absolutely hilarious!
Edoram , I have a light that would be perfect for your heli ... What would your neighbors think about this ?
Man, that copter is pimp! What a great toy!
The toy is a Mikrokopter I assemble it myself so it took me two months only to understand the assembly process and many burns on my hands and a few capacitors explosions to, it supports a lot of weight so it moves very well with the king on it, this only proves that I am still a kid. Jacktheclipper amazing what you got there, certainly it can put me in the top 10 list of UFO hunters in my country. It is part of someting or just a flashlight?
About the temperature…
Yesterday my king was working on hi for about 30 minutes… After I tried to switch it off - almost got a burn on my hand. It was too hot to hold for more than 1 second. Do you have the same result after 30 minutes?
or my king is too overdriven?
s. I have Fandyfire UV-S5 version.
Sorry, C-channel, far too an important question to let go unanswered! Absolutely do NOT mix different battery makes or types. All four batteries need to be the same type and model from the same maker and preferably the same batch if you can. They must be balanced and matched or else you run the risk of bad things happening.
Is there some kind of lubricant I can use between the positive contact of the batteries and the main plate?
I have used a silicone based spray lubricant applied to the driver board with a cotton bud. Its in a can like WD40, but is meant for using on spark plug leads and electrical contacts, and it seems to work well on flashlights too.
