Test / Review: Hi-Max 18650 2600mAh (White)
17 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 21 hours ago
DSC_0026
Official specifications:
  • 68.85(length)x18.60(diameter)
  • 3.7v/2600mAh
  • Build in protected PCB
Hi-Max%2018650%202600mAh%20(White)-info
DSC_0024
DSC_0025
DSC_0027 DSC_0028
DSC_0029
DSC_0030
Hi-Max%2018650%202600mAh%20(White)-Capacity
The two batteries does not have the same capacity or curve. At a sustained 5A load, one of the batteries trips it’s over current protection.
Hi-Max%2018650%202600mAh%20(White)-CapacityTimeHours
In this chart it is easy to see that the shape of the discharge curve is different for the two batteries.
Hi-Max%2018650%202600mAh%20(White)-Energy
Hi-Max%2018650%202600mAh%20(White)-PowerLoadTime
Hi-Max%2018650%202600mAh%20(White)-TripCurrent
When cold the protection trips at around 6A, this drops to 5A when the battery is heated, as can be seen above.
Hi-Max%2018650%202600mAh%20(White)-Charge
The shape of the charging curve for the two batteries are different, I wonder why? Can it be production tolerances, different age of cell or different brands of cell?
Conclusion
The performance of these batteries is better than the typical cheap batteries, but slightly below the brand names batteries.
Because of the difference between the two cells I will only rate it good for a cheap battery.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
Tecmo
Tecmo's picture
Thanks for the review. Very interesting. Great performers for the price in single battery operation anyways.
f42
Last seen: 5 years 11 months ago
I remember an old review of hi max and I remember in that review they are said to be really good batteries, but now I think in this review they turned out to be not that good.
Nationalism is an infantile disease. It is the measles of mankind.
Albert Einstein
fishinfool
fishinfool's picture
Last seen: 2 years 9 months ago
Thanks for the review HKJ!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
SashiX
SashiX's picture
Last seen: 8 years 1 month ago
At least a Hi-Max review from H! Big Smile Thanks, mate, really appreciated Wink
BetweenRides
BetweenRides's picture
Last seen: 3 years 9 months ago
Thanks, HKJ. I'm suprised by results and while not bad, I expected better performance. I will only be using mine in single cell lights.
Ecig
Last seen: 9 years 5 months ago
My first cell from 12-pack tested lot worse than HKJ “bad cell” from the review…
Read here http://budgetlightforum.com/node/11664 (somewhere towards the bottom of the page)
HKJ do you “cycle” cells before testing?
Milan
Last seen: 3 days 19 hours ago
Thanks for the test
Have you stripped any to see what’s inside?
Somehow I cant believe a new Samsung cell would be that bad.
Might be an old stock.
Ecig
Second cell discharging: I really dont know whats happening. Discharging with 1A, and after 15 secs its 3,51V
After 75 sec its 3,49V. After 15 mins its 3,33… (even worse than first one).
LOts of cells (and some of them are real crap, (1000mAh Ultrafire etc) have significantly better voltage sag…
And I expected so much from these.
I dont know if there is some problem with my equipment or what (quite possibly), but nevertheless.
HKJ
HKJ's picture
Milan wrote:
Thanks for the test Have you stripped any to see what's inside? Somehow I cant believe a new Samsung cell would be that bad. Might be an old stock.
I have not stripped any of them. But try comparing them to other brands in my comparator, the B battery is close to the Sanyo cell, it has less capacity and the voltage drops faster under load (Might be due to age), but the curve shape is the same. The A battery looks much more like the LG 2600.
I.e. they might both be good batteries, but it is not very nice to sell them as the same battery.
Note: I mostly compare the 0.2A discharge curve and the charge curve.
Milan
Ecig:
It might be caused by bad contacts, but it must have been really bad.
Do you use included imax wires or have your own?
Do they match in weight?
Ecig
Milan wrote:
Ecig:
I think they match in weight.(I dont have precise digital scale now, ebay seller received money for it but tdidnt ship it Big Smile )
MAybe contacts are not good, but Im testing other cells with those same setup, so even if numbers are not 100% accurate, looking comparatively these cells are nothing special
Milan
I have many, very nice and useful item
Yeah, this happens to me more and more often Sad
That abeyerr/toymodel55/demonerrr/demon99 – its a known ebay scammer
basically if it has below 99% its another of their shops
I mostly use and recommend this scale:
http://www.ebay.com/itm/Digital-Pocket-Jewelry-Electronic-Scale-0-01g-20...
wshyang
Last seen: 9 years 1 month ago
I’m saddened to say this, but it seems like the quality of these Himax batteries have dropped very significantly since this review was posted.
Just got round to testing a dozen I ordered a month ago, and the performance of these are quite literally no better than used laptop batteries I routinely test. Simply horrible. Buyers beware!
Update: my test results on a batch ordered on 25th July can be viewed here:
http://budgetlightforum.com/node/12756
bose301s
bose301s's picture
Last seen: 1 year 1 week ago
All this makes me feel better about always going for Panasonic batteries.
sb56637
sb56637's picture
Last seen: 3 hours 20 min ago
Thanks as always! Frontpage’d and Sticky’d.
iron potato
My 6 pcs Hi-max also bought from pinyi, last year August till now, many times used till pcb tripped.
Recheck all of their capacity, charged with Xtar SP2 at 1A, rest for 10mins, discharge with iMax at 1A to 3V.
A : 2518mA
B : 1600mA
C : 1214mA
D : 2322mA
E : 1968mA
F : 2621mA
Cell A & F will be on TK35’s battery carrier, cell D & E also use back for light load. Cell B & C, would tear off & have a look.
