Where can I get...
4 posts / 0 new
Innerlight
Last seen: 1 month 1 week ago
Where can I get...
Hi,
Anybody know a source for wolf eyes body extenders?  I was asleep at the switch and let a couple get by me at CPF.  I have since been looking around and noone seems to carry them any more.
Thanks for any info
-Rick
Don
Don's picture
Last seen: 2 years 3 months ago
The WolfEyes stuff is Surefire interchangeable isn't it? If so, the Solarforce stuff should do the trick.
I've never owned any WolfEyes lights so I could easily be way off here.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Innerlight
Thanks for the quick reply.  I just recently picked up an L2 host based partly on the reccomendations here.  Real nice host, so thanks BLF.
Anyway the diameter of the WE is larger than the Surefire/Solarforce.  They are not interchangeable.  Pila used to be interchangeable but that is going back a good 5 years before they changed their models from the 3glx or whatever it was.  Its a real shame.  If you get a chance to pick up an old WE body for short money you should give them a try.  The Sniper/Raider line is p60 compatable and the Rattlesnake is D36 compatable.  I really love mine, I just can't find the tubes anymore.
Don
Don's picture
Ah well, it was worth a try...
The problem is that unless you have access to a lathe, getting stuff machined in the EU/US is just too expensive to consider. I was quoted roughly two day's of the national average pay here to bore out a 60mm long aluminium tube by 3mm.
If you do know a machinist, you can probably get it done for two or three beers. Threading is a pain to do on a lathe though. If you can find appropriately sized tubing, you may be able to find an appropriate tap and die set to cut the threads yourself. Which is a lot more fun anyway. Just make sure the tubing is made of something fairly soft or you'll need to hire King Kong to apply the required force.
There are a few folks around here with access to machine shops - one of them will hopefully chip in with an offer to help.
