You might want to wait a week or two
You could get the King it has 4 18650s in paralell.
Oooh, do tell….
Very Nice!!!
I can tell you now it will not have 1 (one) emitter in it.
I’ll take it.
I’ll be watching for the details on this one!
or will it be for sale, or both?
GIVE DETAILS! DO YOU KNOW HOW CRUEL IT IS TO LEAVE US IN THE DARK!
Now I’m just sitting here wondering if I should put more money in my paypal…
The battery life would be horrendous
Side switch w/ lockout. Shooting for 1500 OTF. Very good heatsinking no cheap dropin design. 18650 battery tube is a possibility.
Assuming a 3*xml with each driven at 2.5A, that would be approximately 30 minutes on high for a single 4000mAH cell. That would be acceptable to me as long as it also has a medium 600 lumens and a low~100 lumens mode. Or else it could have cells in parallel. I just don’t want to have cells in series where you would be well advised to balance the cells periodically.
One other option is using sealed AGM lead acid batteries. But since I posted under the 26650 topic . . .
SOLID Jason!!!
Also looking forward to your single emitter design too!!
Multi XM_Ls with a single 26650 or18650 will not be good you need multi cells.
You should get the Sky Ray King. Which has 3 XM-Ls and takes 3 18650 batteries.
Not true. The 18650CGR can do 10+ amps discharge without sweating. IMR cells should be able to handle any 3-up draw needed.
ElectroLumens BigBruiser is a 3XML beast that runs direct drive on one 26650. It’s over the origional posters budget. I just mentioning it because it is an awesome amount of light off one cell
Are you making more than one ?
It’ll be for retail. If you look at it hard enough you’ll know what brand it is (kinda obvious since it’s a 26650). It should be for sale only through my company since it is my project. I want this to be a good reliable work light, not a 10 minute toy light so we’re not going for 3000+ lumens for 5 minutes.
