The toy is a Mikrokopter I assemble it myself so it took me two months only to understand the assembly process and many burns on my hands and a few capacitors explosions to, it supports a lot of weight so it moves very well with the king on it, this only proves that I am still a kid. Jacktheclipper amazing what you got there, certainly it can put me in the top 10 list of UFO hunters in my country. It is part of someting or just a flashlight?
About the temperature…
Yesterday my king was working on hi for about 30 minutes… After I tried to switch it off - almost got a burn on my hand. It was too hot to hold for more than 1 second. Do you have the same result after 30 minutes?
or my king is too overdriven?
s. I have Fandyfire UV-S5 version.
Sorry, C-channel, far too an important question to let go unanswered! Absolutely do NOT mix different battery makes or types. All four batteries need to be the same type and model from the same maker and preferably the same batch if you can. They must be balanced and matched or else you run the risk of bad things happening.
I have used a silicone based spray lubricant applied to the driver board with a cotton bud. Its in a can like WD40, but is meant for using on spark plug leads and electrical contacts, and it seems to work well on flashlights too.
Thanks Johnny Mac. appreciate your answer… I was hoping that it could be used as I read that the SkyRay King operates the batteries in Parallel. Think it is time to make some new purchases…
I may go for it. Does anyone have internal pic of the Skyray and the other clones to see how the leds sit and the build quality. Thiws my be just the same light internally. Manafont does not sell any poor quality light apart from the Ultrafire x1
