Review: Skyray King (3xXM-L - 4x18650)
Edoram , I have a light that would be perfect for your heli ... What would your neighbors think about this ?
Man, that copter is pimp! What a great toy!
The toy is a Mikrokopter I assemble it myself so it took me two months only to understand the assembly process and many burns on my hands and a few capacitors explosions to, it supports a lot of weight so it moves very well with the king on it, this only proves that I am still a kid. Jacktheclipper amazing what you got there, certainly it can put me in the top 10 list of UFO hunters in my country. :slight_smile: :slight_smile: It is part of someting or just a flashlight?
About the temperature… :frowning:
Yesterday my king was working on hi for about 30 minutes… After I tried to switch it off - almost got a burn on my hand. It was too hot to hold for more than 1 second. Do you have the same result after 30 minutes?
or my king is too overdriven?
s. I have Fandyfire UV-S5 version.
Sorry, C-channel, far too an important question to let go unanswered! Absolutely do NOT mix different battery makes or types. All four batteries need to be the same type and model from the same maker and preferably the same batch if you can. They must be balanced and matched or else you run the risk of bad things happening.
Is there some kind of lubricant I can use between the positive contact of the batteries and the main plate?
I have used a silicone based spray lubricant applied to the driver board with a cotton bud. Its in a can like WD40, but is meant for using on spark plug leads and electrical contacts, and it seems to work well on flashlights too.
+1. Works very well for me. Put a very thin layer, it lasts for months yet doesn't seem to interfere much with electrical contact.
Thanks Johnny Mac. appreciate your answer… I was hoping that it could be used as I read that the SkyRay King operates the batteries in Parallel. Think it is time to make some new purchases…
My initial intention…
SKYRAY KING Mimic $43.90
Any volunteers? :bigsmile:
yes, me, but manafont doesn’t ship products to my country and doesn’t acept credit card payment, and I dont have paypal…
Hmm…they say it’s a Skyray King and it sure looks authentic. If I didn’t already have one I’d go for it.
I may go for it. Does anyone have internal pic of the Skyray and the other clones to see how the leds sit and the build quality. Thiws my be just the same light internally. Manafont does not sell any poor quality light apart from the Ultrafire x1
Then again I can get the original for about $52 or is it the original. Apart from the colour what's the difference visually?
How many Skyray kings are there? The mimic
FandyFire UV-S5
SKY RAY KING
UniqueFire FC-UF-V
SupFire M6
KinFire 3
Sky King getting cheap and my dream will become true soon :bigsmile:
I got a set from KD when they have the offer and I believe I got the MIMIC set.
The set that i got was exactly the same as what manafont is selling as mimic copy.
1. Sky Ray logo different from original and is smaller.
2. Lanyard is different from original and is dark brown with lower quality
3. Driver board is different with rough edges.
4. Spring end is different. rattling sound even with 4 battery inserted and screwed tight.
I do not have an original copy to compare the performance…
All these photos of original are compared with the reviews posted in BLF.
Edit: I might be wrong about it.
That’s too bad :frowning:
Can you use someone as a middleman?
C-channel can you post some pics please.
