Test / Review: "Himax 2600" 18650 batteries from "pingyi.co.ltd" on eBay (very poor results)
I’ll definitely be redoing the tests in time. Been pondering about it and was worried that perhaps my attempts to mimic HKJ’s battery testing clamp might be sub par.
I won’t want to run the risk of putting people off a good supplier, so I will be waiting for this el cheapo DX charger to arrive and cannibalise its case and battery holder for the sake of… testing!
Please post your results too, your post was actually the one that set alarm bells going off in my head.
So far, no Hi-max/ low-max for me.
I will post my results, I dont have much time, but Ill do my best, Im just measuring one of these 3 cells second cycle, to see will capacity improve.
But, capacity wasnt some big reason for me to buy them (after all its only 200mah more than standard 2400mAh), small voltage sag was the main reason, and all three I tested today have voltage sag at 1A pretty same as almost any other cheaper cell… In 1 minute it drops to around 3,6V, depending of the cell. I dont have equipment to make diagrams, Ill just post their capacities.
WShyang,
I have had a lot of luck with these batteries. Not even an hour after you posted this the news made it to me. I’m interest in knowing where you are getting the “US18650GR” or “MEHM4CA” can you please peel the the battery back to confirm this? I will replace what you damage either with the HI-MAX that i stock or another 2600 brand of your choice that i stock.
These batteries are done by SHENZHEN PINGYI ELECTRONICS CO in Shenzhen,China. They are supposed to be a Samsung core cell and they are fair people to work with, yet this has me worried. I will talk to the PINGYI sales rep. tonight about this.
Please send me an email,
shane@protacticalshop.com
-Shane
My results until know, dscharging at 1A to 2,8V
1. cell: (1) 2293AH (2) 2238 Ah (first and second cycle… I know, little weird)
2. cell: 2113mAh
3. cell: 2232 mAh
All have large voltage sag same, worse or little better than much cheaper cells.
PS: resting voltage after discharging by 1A to 2,80 V is 3,43V….
SO that would be like at least 0,63V voltage sag.
Ecig,
How depleted where the batteries before you did a recharge? Also when you recharged them what was the trickle, 500mAh or 1000mAh?
-Shane
I use XTAR WP2 chargers, old and new one, so Im not sure with wich one I charged them, was it with 600mAh (old one) or 1000mAh. I dont thik that so important. It is?
I dont understnd first question, sorry, can you clarify?
Hi Shane. Glad to see you here.
Guys this is one of my personal favorite guys to deal with.
I highly recommend him to anyone needing flashlights, batteries or chargers.
Brad
On the WP2 II charger there is a dip switch on the top that reads 0,1,2. The 1 is 500mAh the 2 is 1000mAh. 0 is to charge a 0.5v device off the batteries(Reverse). I suggest draining the batteries to a weak state but not completely then do a recharge on dip switch 1. The charge will take maybe 3-4 hours. When you get the time try your test again. I would like to see if we get to the 2600mAh.
-Shane
Ok, I will tomorrow. (must go to sleep now, its 4AM here, hehe)
I just hope Ill figure out how to drain batterie to a weak state (I mean I know how to discharge via USB, but Ill probably have to out it out every now and than to check the voltage…). to wich resting voltage?
And than to charge them with 1A, Ok
Hey Brad!
Thanks man… Honestly, I try to stay off these forums as i get beat up with questions.
Guys, I have bought several sets of Hi-Max from Shane and they are some of my better cells. I hope this all gets sorted out Shane, I'm sure you are more worried about this than anybody.
I just did it for one, seems like it is quite unlike anything I’ve seen, apparently there is no other layer of shrinkwrap inside and the printing is on the cell itself:
And this one’s a Sony.
I’ll try to find one with the Sanyo. Just as a disclaimer though, I didn’t see the “MEHM4CA” through the shrinkwrapping, but what gave it away for me was seeing some of the distinctive “D” symbol that is normally on the Sanyo cells.
A comparison with a “real” Sony:
Pardon the gross mouse! Now I better go wipe it with some detergent!
Better res picture
Haha,
Okay while i was writing this thread you posted pictures…
Wshyang,
I am not sure about the set of batteries you received but i promise mine are the real Samsung core cells. You did not get the batteries from me which makes it a bit harder to correct the issue. Pingyi just puts the label on the units but Samsung creates the cells for us. I’m working with Pingyi to hopefully find what happen with why you have a Sony cell. This swap of cells error would happen in the Pingyi manufacture and not Samsung. I would like you to get some pictures of the battery once the label is pulled please.
I greatly appreciate your interdependent testing, but after review i feel that you discharge current is beyond Samsungs core preparation rang. I still want to confirm your test so i just bought the West Mountain Radio CBA IV. This way i can replicate your test. It looks like a great tool and i can’t wait to use it!
I import these batteries in bulk and jump through hoops to get them in the country as they are classified as dangerous goods. I have document upon document of lithium Ion battery mambo jumbo… I ended up getting the Actual -SAMSUNG SDI Confidential Proprietary – Document for these batteries. I was asked not to release the entire document, but i wanted to give all the back yard battery Test guys, which i appreciate very much, what test specs. should look like when doing their testing.
This is all copy and paste and i hope this can lay a little ground for some.
This is the normal Spec. of the battery :slight_smile:
3.1 Nominal Capacity 2600mAh (0.2C, 2.75V discharge)
3.2 Minimum Capacity 2550mAh(0.2C, 2.75V discharge)
3.3 Charging Voltage 4.2 ±0.05 V
3.4 Nominal Voltage 3.7V
3.5 Charging Method CC-CV
(constant voltage with limited current)
3.6 Charging Current
Standard charge: 1300mA
Rapid charge : 2600mA
3.7 Charging Time
Standard charge : 3hours
Rapid charge : 2.5hours
3.8 Max. Charge Current 2600mA(ambient temperature 25℃)
3.9 Max. Discharge Current 5200mA(ambient temperature 25℃)
3.10 Discharge Cut-off Voltage 2.75V
3.11 Cell Weight 47.0g max
3.12 Cell Dimension
Height : 65.00mm max
Diameter : 18.40mm max
3.13 Operating Temperature
Charge : 0 to 45℃
Discharge: –20 to 60℃
3.14 Storage Temperature 1 year : –20~25℃(1*)
3 months : –20~45℃(1*)
1 month : –20~60℃(1*)
Note (1): If the cell is kept as ex-factory status (50% of charge),
the capacity recovery rate is more than 80%.
This Should be the standard test conditions :wink:
6.1 Environmental Conditions
Unless otherwise specified, all tests stated in this specification are
conducted at temperature 25±5℃ and humidity 65±20%.
6.2 Measuring Equipment
(1) Ammeter and Voltmeter
The ammeter and voltmeter should have an accuracy of
the grade 0.5 or higher.
(2) Slide caliper
The slide caliper should have 0.01 mm scale.
(3) Impedance meter
The impedance meter with AC 1kHz should be used.
This is how the charge should be set up. :bigsmile:
7.1 Standard Charge
This “Standard Charge” means charging the cell with charge current
1300mA and constant voltage 4.2V at 25℃ for 3hours.
7.2 Standard Discharge Capacity
The standard discharge capacity is the initial discharge capacity of the cell, which is
measured with discharge current of 520mA with 2.75V cut-off at 25℃ within 1hour
after the standard charge.
Standard Discharge Capacity ≥ 2550mAh
7.3 Initial internal impedance
Initial internal impedance measured at AC 1kHz after rated charge.
Initial internal impedance ≤ 100mΩ
7.4 Temperature Dependence of Discharge Capacity
Capacity comparison at each temperature, measured with discharge
constant current 520mA and 2.75V cut-off after the standard charge is
as follows.
Charge Temperature Discharge temperature
25℃ –10℃ 0℃ 25℃ 40℃
Relative Capacity 50% 80% 100% 80%
Note: If charge temperature and discharge temperature is not the same,
the interval for temperature change is 3 hours.
Percentage as an index of the capacity at 25℃(=2550mAh) is 100%.
7.5 Temperature Dependence of Charge Capacity
Capacity comparison at each temperature, measured with discharge constant current
520mA and 2.75V cut-off after the standard charge is as follows.
7.6 Charge Rate Capabilities
Discharge capacity is measured with constant current 520mA and 2.75V cut-off
after the cell is charged with 4.2V as follows.
Note: Percentage as an index of the capacity at 25℃(=2550mAh) is 100%.
7.7 Discharge Rate Capabilities
Discharge capacity is measured with the various currents in under table and 2.75V
cut-off after the standard charge.
7.8 Cycle Life
Charge temperature Discharge temperature
0℃ 25℃ 45℃
Relative Capacity 80% 100% 80%
25℃
Charge Condition
Current 0.2C
(520mA)
0.5C
(1300mA)
1.0C
(2600mA)
2.0C
(5200mA)
Cut-off 7h or 0.05C 2.5h or 0.05C 2.5h or 0.05C 2.5h or 0.05C
Relative
Capacity 100% 95% 90% 80%
Discharge Condition
Current 0.2C
(520mA)
0.5C
(1300mA)
1.0C
(2600mA)
2.0C
(5200mA)
Relative
Spec. No. ICR18650-26F Version No. 0.0
4
Each cycle is an interval between the charge (charge current 1300mA) with 2.5h or
0.05C cut-off and the discharge (discharge current 1500mA) with 2.75V cut-off.
Capacity after 299cycles and plus 1 day, measured under the same condition
in 7.2
Capacity ≥ 1785mAh(70% of the capacity at 25℃)
7.9 Storage Characteristics
Capacity after storage for 30days at 25℃ from the standard charge,
measured with discharge current 1300mA with 2.75V cut-off at 25℃.
Capacity retention(after the storage) ≥ 2040mAh (80% of the capacity at 25℃)
7.10 Status of the cell as of ex-factory
The cell should be shipped in 50% charged state. In this case, OCV is from 3.65V to
3.85V.
-Shane
Figured I can get adventurous with the two particularly crap cells too:
Can you please send those to me in an email so i can get those over to Pingyi? I would be upset if they sent those to me when i clearly ask for Samsung core batteries.
I will need to ask but, when i put my orders in, i have to wait up to 8 weeks sometimes for the manufacture to finish my order. It could be that i ask for the Samsungs and that is why i wait…???
-Shane
So to clarify the same Himax labelled cells on the outside can be spec-ed differently inside? That’s great, maybe next time I’ll order from you instead, but do you ship internationally?
Yes, I admit that 2.5A discharge is generally high. I tend to test my old cells at only 1.5A discharge, but I just figured that… these are supposedly new, and I don’t have two days to do the testing if they are all supposedly perfect :slight_smile:
So pingyi make these or buy these wrapped. I think they got a great deal on some pre wrapped ones and thought we can sell these and make a great profit and who will know the difference. Most user's wouldn't so even if they have to refund a few people they are still in front. Probably why I only buy panasonics now
Not a problem, you can just copy my post and send it over to them, my phone automagically uploads onto Google+, so that’s where all my photos are uploaded.
