Review: Roche F22 NW (Cree XM-L T6 | 1-2 x 26650 or 18650)
52 posts / 0 new
_the_
_the_'s picture
Last seen: 2 weeks 1 day ago
Reviewer's Overall Rating: ★★★
Summary:
Battery: 1-2 x 26650 or 18650 (or 3 x SubC)
Switch: Side switch, electornic clicky
Modes:Ramping: High->Low (with memory), Hidden Strobe / SOS
LED Type: XM-L T6 3C (NW)
Lens: Glass
Tailstands: Yes
Price Payed: $55 (+ $5 for extension tube)
Date Ordered: August 2012
Pros:
  • Side switch
  • Very nice UI
  • Hidden Strobe / SOS
  • Available as NW
  • Very good runtime with 2 x 26650
  • Stepless ramping
  • Low enough low
  • No / negligible parasitic drain
  • No PWM, even on lowest low
  • Tailstands
  • Very good build quality
  • Seemingly waterproof
  • HAIII anodized
  • Comes in a good box
  • Lanyard, 18650 adapter, and two extra O-rings included
  • Optional extension tube allows the use of 2 x 26650 OR 3 x SubC NiMH cells
Cons:
  • Ramping might be too fast or slow for someone, just perfect for me. Smile
  • Double click time is very short, requires practice to access 2nd or 3rd hidden mode.
  • Came without a second 18650 adapter for extension tube (Need to ask Ric about this)
  • Bezel is too ... (I don't dare to say the t-word here) -> I might need to Foyzel it later..
Features / Value: ★★★★
The light comes in a plain package. Nothing fancy, but keeps the flashlight safe during postage.
The sticker says something in Chinese + F22 + something. Smile
Package contains the light itself, optional extension tube, a nice lanyard, and two extra O-rings
Features are good: Adjustable brightness (about 20 to 800lumens OTF), side switch (electronic clicky) and hidden blinky modes.
UI is very nice: One main mode with memory, ramping to set the main mode brightness, and three hidden blinky modes.
Ramping is activated with a long press of the switch: Light starts to brighten and blinks once in full brightness. If you keep the switch pressed, the light ramps down and blinks once in lowest setting. Just release the switch when desired brightness is reached and the light memorizes it (memory works even when replacing the batteries).
The hidden blinky modes are accessible with quick double click when the light is on. First double click activates the continuous strobe (full brightness), second double click activates an intermittent strobe (1s strobe, 1s off), and third double click brings us a pretty fast SOS with 4s pause.
Double click time is so fast that you can even use Morse code with the switch without changing modes!
If anyone is worried about the light turning on accidentally, I can comfort you by saying that the light can be locked out simply by unscrewing the head or tail about 1/8 - 1/4 turns.
Value for money: Good.
Design / Build Quality: ★★★
Design is very nice. Side clicky suits this light very well.
The anodization is very good overall, glass lens looks nice, and the electronic switch feels reliable.
Let's see some details..
Stainless steel bezel and nice cooling fins:
Well positioned & very functional side clicky:
Well centered NW emitter with nice tint in a SMO reflector.
The threads were anodized, very smooth, and well lubed. Just like I want them! Throw in a beefy O-ring and the light is ready for success..
And the same in the other end:
Here are the three main parts disassembled:
Note also the low resistance features in both springs. First time for me to see this kind of things in a budget light! Looks pretty thin, but nice gesture anyways..
Tailcap spring:
Head spring. Note also the plastic washer and upside down design of the spring!
The stainless steel bezel was very tight and I was a bit hesitating to unscrew it, but hey: I'll do whatever to keep BLF members happy! Smile
So here's some pics of disassembled head. Bezel, glass lens, O-ring and reflector removed. Looks very clean here. Plastic cup keeps the emitter contacts safe.
Nothing else to remove on that side, let's continue on the other side.
The driver is secured with a brass retaining ring:
Another photo of the driver itself:
Other side of the driver. Note the brass ring around the driver.
Note also the interesting thing: There is no pill, but the emitter & star is glued on the head itself. Aluminum layer below the star is quite thick and provides near perfect thermal path to the cooling fins. I can't wait to see how good this performs in runtime & temperature tests!
Here you can see the bottom of the side switch:
And here's the side switch from the other side:
The electronic switch is kept on place with a retaining ring which, together with the switch cap, seems to be very waterproof:
Very clean machining also here:
Here is the whole light disassembled. Note also the beefy O-ring underneath the lens.
Some measurements:
Length: 163mm (230mm with extension tube)
Head diameter: 48.9mm
Body diameter: 33mm
Tail diameter: 34mm
Weight: 368g with cell and lanyard (= ready to use), 274g without (324g with extension tube)
And same with pictures:
And the bottom line in the quality: Absolutely nothing to complain. Very good from head to tail!
Battery Life: ★★★★
Good! Up to 2 x 26650 will allow long runtimes.
I measured the tailcap current with one cell and got results of 2.97A on high and 0.05A on low. Two cell results are half of those.
This would give almost 1.5h runtime on high (3h with 2x26650 config) and over 80h on low (160h = over 6 days with 2x26650)!
Electronic switches are known to have some parasitic drain, but in this case it was unmeasurably small => not an issue.
Light Output: ★★★★
This light is just bit less bright than my XinTD C8 NW, but I would still classify this as "bright" (as a single emitter light).
Runtime & thermal tests to follow. Stay tuned.
I estimate (ceiling bounce + "known" references) the light output to:
- about 800 lumens on high
- about 20 on low
White wall beamshots (WB: Daylight)
Low
High
Beam angle, low
High
Outdoor beamshots
50mm, 2.0s, f/4.0, ISO200, WB:5000K. Distance to the tree in the middle: 50m
Low: (This was visible in the real life, but really low)
High:
Compared to XinTD C8 NW (Mouse over for XinTD)
Summary: ★★★★
Very good flashlight with nice features, very good runtimes (especially with the optional extension tube) and superb build quality.
Verdict: Highly recommended!
The End (pun intended):
Thanks for reading & watching. Hope you enjoyed the review!
=the=
Edited by: sb56637 on 09/02/2017 - 11:54
Woody
Woody's picture
Last seen: 3 weeks 3 days ago
Fantastic photographs and review the, thanks.
Langcjl
Langcjl's picture
Last seen: 3 years 5 months ago
Great job on this review!
Piers said " ....but who wants enough light, when you have the option for far too much "
Sharpthangs
Sharpthangs's picture
Last seen: 8 years 4 months ago
Great pics. Looks like another one to add to the list of lights I want badly.
Very well done light.
Philipp
Philipp's picture
Last seen: 7 years 11 months ago
oh what a gorgeous light! Sideswitch, ramping, extension tube, anodized square treads…. Love
Makes me want to pick up my first “big one”…
And I agree with you that the bezel is to tacti**** for my taste, but that would be really the one and only thing i would change.
You said Sub-C, so I guess that normal C -Cells would not fit? because wikipedia says there 27mm….instead of 26mm of the 26650’s. And three of them would be 150mm long instead of the 130 from the 26650…hmmm can you confirm that?
Pok
Pok's picture
Last seen: 2 years 1 month ago
Very nice the review Wink
2.97A on high.
1. Could you measure currents for 1 cell @ 4V , 3.7V , 3.5V
2. Does it has memory mode when you take out battery?
Thanks
kreisler
kreisler's picture
Last seen: 7 years 8 months ago
Great photos and very helpful review!
Thanks for your efforts!!
*FMI* i got 4 i/o sh
_the_
_the_'s picture
Philipp wrote:
You said Sub-C, so I guess that normal C -Cells would not fit? because wikipedia says there 27mm....instead of 26mm of the 26650's. And three of them would be 150mm long instead of the 130 from the 26650...hmmm can you confirm that?
I don't have any NiMH C cells, but Duracell alkaline C measures at 25.5mm and can be dropped in the tube (inner diameter is 26.5mm).
However, three standard C cells are too long for one extension tube. If my calculations are correct, four C cells would fit near perfectly with two extension tubes.
=the=
_the_
_the_'s picture
1. I'll try that as soon as I have some extra time.
2. Yes it has.
=the=
monanoke
monanoke's picture
Last seen: 1 year 3 weeks ago
Thanks for the review! Just pulled the trigger.
z
C
fishinfool
fishinfool's picture
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
gords1001
gords1001's picture
Last seen: 3 years 3 months ago
Damm I like this light, I just promised Mrs gords I won’t buy any more lights for a while. Sad
how2
Last seen: 7 hours 39 min ago
Good! Up to 2 × 26650 will allow long runtimes.
I measured the current at the switch and got results of 2.97A on high and 0.05A on low.
What’s the amps on 1 battery?
_the_
_the_'s picture
how2 wrote:
Good! Up to 2 x 26650 will allow long runtimes. I measured the current at the switch and got results of 2.97A on high and 0.05A on low. What's the amps on 1 battery?
Sorry for being unclear. I'll try to update that to make it more readable.
Those were measured with one cell. Two cell results were about half of those (= 1.50A & 0.025A)
=the=
eebowler
eebowler's picture
Last seen: 5 days 7 hours ago
Thank you the for your review! 1) The beam profile of the F22 looks a little ringy, can you confirm? 2) The F22’s driver says “LD 33” on it. Visually comparing it to the LD 33 driver HERE they look almost identical except for the second black wire the F22’s driver has attached to it (goes to the switch). The specs for the driver on the website are completely different. Sad the can you verify at all the differences between the driver in the F22 and that shown in the link? I’m wondering if the driver linked can perform like the driver in the F22 with a little mod. Big Smile
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
ZW99GT
Last seen: 2 years 4 months ago
Really cool light! Thanks for the review!
Hikelite
Last seen: 5 months 4 weeks ago
eebowler wrote:
Thank you _the_ for your review! 1) The beam profile of the F22 looks a little ringy, can you confirm? 2) The F22's driver says "LD 33" on it. Visually comparing it to the LD 33 driver [url=http://www.intl-outdoor.com/ld33-triple-xml-26a-917v-circuit-board-p-489..., they look almost identical except for the second black wire the F22's driver has attached to it (goes to the switch). The specs for the driver on the website are completely different. Sad _the_ can you verify at all the differences between the driver in the F22 and that shown in the link? I'm wondering if the driver linked can perform like the driver in the F22 with a little mod. :D
They are two different drivers, one with 3-9V input for 1 led and one with 9-17V input for 3 leds, that is clear on the Chinese forums.
Lothar
Lothar's picture
Last seen: 3 days 9 hours ago
Great review the !
Hikelite, do you have a link for the 3-9V version? Can it be bought separately? Is it a regulated driver?
Thnx
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
CheapThrills
CheapThrills's picture
Last seen: 1 hour 52 min ago
Any comments, can this light house 2 x of these King Kong Raised Tops?
http://www.intl-outdoor.com/kingkong-inr26650e-raisedtop-4000mah-liion-b...
Better recommendations? ICR or INR better for this use?
Pok
Pok's picture
If you want to use 2×26650s in series , recommended protected cells.
http://budgetlightforum.com/node/8799
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 2 days ago
Great review, bud! Looks like a real nice light. 8)
380long
380long's picture
Last seen: 8 years 11 months ago
Do you have to use protected cells with this light? I have king kongs, IMR’s and INR 26650 batteries…will any of these safely work? I ordered this light thinking I could use one of these pairs of batteries!
I can't remember the last time I bought a flashlight I "NEEDED".
Johnson
Last seen: 9 years 2 weeks ago
I bought and just received one of these ROCHE F22’s with the optional extension tube. Like the OP, I immediately noticed that the second plastic sleeve (for using the 18650 calls) was absent. I contacted cnqualitygoods.com and was told that a second sleeve is NOT included. This is deeply disturbing..
  • No indications when ordering that a second sleeve isn’t included, even when purchasing the 2-battery extension.
  • No mention from customer service during our 3 email exchange, that I may purchase one.
  • Just “sorry, the second sleeve isn’t included”.
So now I’m forced to fabricate a sleeve just to use 2 cells.
Bottom line, cnqualitygoods.com won’t be seeing my funds in the future… that’s for sure.
_the_
_the_'s picture
Welcome to BLF Johnson! You'll love being here! There must have been some kind of miscommunication. Ric is usually very friendly and helpful. The second sleeve can be ordered separately for $1.5.
I just received the optional flat bezel ($5) and I think the light looks much better with it. This is of course a matter of taste..
As speculated before, the second extension tube allows usage of 4 x C cells. I don't have any NiMH Cs, but the light seemed to work also with alkalines, starting with 0.6A and quickly sagging to steady 0.5A (at TC).
TF protected cells seem to fit also in 2 x 26650 configuration, but are on the limit. Anything longer might have problems with tailcap locking out.
=the=
Johnson
the wrote:
Welcome to BLF Johnson! You’ll love being here! There must have been some kind of miscommunication. Ric is usually very friendly and helpful. The second sleeve can be ordered separately for $1.5.
Appreciate the info.
It took me 3 emails to (politely) relay my concerns – only to arrive at being forced to pursue different options… for a problem that should have NEVER existed to begin with. Why no second sleeve when the optional extension tube is clearly specified during ordering?… and it’s not even listed in the ‘options’ on the product page. Worse yet, no resolution even offered, let alone, NOT being informed that ‘apparently’ I had the opportunity to purchase one… and have it shipped when the initial order was made.
Here’s the last of 3 email communications (please note: to get the second sleeve, they attempt to bait me into a second order – The way I see it, it’s like buying a car, only to discover long AFTER you take delivery, that spare tire is not included…. . Sorry, they lost a future customer over a measly buck-fifty piece of plastic.|():
[quote]
“Dear xxxxxxx
Each flashlight only equipped with one plastic sleeve.
If you want it, we may offer a free one to you next time.
2012-09-06
Best regards
Merry
CS”.
[end quote]
They know who I am, my concerns, and my shipping address. The solution is in their court.
Bort
Bort's picture
Last seen: 6 hours 22 min ago
Why censor our use of the term tacticool?
We should declare a day in September to be tacticool day, on this day we discuss all things tacticool and showcase the best and worse examples :bigsmile:
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
CheapThrills
Tacticool would be a good brand-name for a small flashlight manufacturer Big Smile
Thanks Pok for giving the link.
So, I guess these would be OK for F22 :
http://www.manafont.com/product_info.php/trustfire-protected-tf-26650-37...
_the_
_the_'s picture
CheapThrills wrote:
I guess these would be OK for F22 : http://www.manafont.com/product_info.php/trustfire-protected-tf-26650-37...
They work fine in mine, but the length is "on the limit" (= tight) => manufacturing tolerances may cause them to be just too long causing tailcap lock out.
=the=
380long
380long's picture
Can non protected 26650 cells like the king kong’s be safely used in this light with the extender?
CheapThrills
the wrote:
They work fine in mine, but the length is “on the limit” (= tight) => manufacturing tolerances may cause them to be just too long causing tailcap lock out.
Just the thing I would like to avoid…
Are all protected’s too long for this light?
_the_
_the_'s picture
CheapThrills wrote:
Just the thing I would like to avoid... Are all protected's too long for this light?
I have only TF and Keygos protected 26650s and both of them work in my F22 (but are tight fit: Adding one 5c coin to negative end causes TC lockout)
=the=
