skytop, a triple XM-L wouldn’t throw further, actually it probably would throw less.
You got my attention!
Looks at the specs for TN31 specs:
- LED: Cree XM-L U2 LED with a lifespan of 20+years of run time *
- Max 1147 lumen output using 3 * 18650 batteries *
- Level 1: 0.5 lm. 2000 hours; Level 2: 21 lm. 140 hours; Level 3: 146 lm. 22 hours; Level 4: 366 lm. 9 hours;
Level 5: 620 lm. 5 hours; Level 6: 1147 lm. 2 hours; Standby: 65 uA; Strobe: 1147 lm. 4 hours.
- Working voltage: 4V to 13V *
- Max runtime: 2000 hours *
- Max beam distance: 700 meters *
- Peak beam intensity: 75000cd *
- Impact resistant: 1.2 meters *
- Waterproof to IPX-8 standard, 2M *
- 201.70mm length, 79.00mm bezel diameter
- Weight: 452.80g without battery *
The ones I marked * are spec’ed to be exactly the same. This is definitely a flashlight to watch for.
YESsss! nice light and $100 cheaper than the thrunite.I want to see beamshots/reviews first,hopefully not hype.
Recently went on a night hike with kramer5150 with this light and the TN31. The TN31 achieved 115k lux while my prototype achieved 77k lux at the lower drive current. Hoping to break 80k and closer to 90k at the high drive current. Throwing them up on the trees at 100+ meters it was hard to tell the difference, only when side by side.
I might pick one up for modding purposes, if the build quality is good enough I have a few designs you might be interested in.
Been meaning to lathe my own out for a while, but if I could find an actual producer to make enough to go around that would be even better.
Got any specs on the type of aluminum and lens used?
Also, in the name of all that is good, slap a low profile SS bezel on there, it would cost what, an extra couple dollars?
I think my HD 2010 lasted a week before the bezel was chewed into a foy type bezel by concrete.
Interested Jason… Nice to see this coming full circle.
That prototype was a nice, well made light for sure. I like the price target, definitely under-cutting the TM31. Double the lux of XML lights like the HD2010, and STLV2. I think the less you can sell it for the more CPF and BLFers will rave about it.
The 3.4A Stanley fatmax, and Defiant spotlights I brought that night did about 75-78K, and they were about $80-90 builds. So youre light here takes it up a notch.
interested !!
I wished for this the second I asw the TN31. Now that someone made it I kinda feel guilty…. I’m sure the guilt will leave once I have the funds to buy one
This looks very cool and the price sounds great!!! This is what we all have been waiting for!!!
Nice work I’m interested, will it be ready before or after Christmas ?
Should be ready in 3 weeks
Looks good. Are any of those stats to ANSI FL1?
You’d need 122.5K lux @ 1m to throw 700m (.25 lux).
The light gets 80k lux easily. 90k lux is planned
Neither of which will throw 700 meters...
It looks like a great light but 90K lux @ 1m will throw 600m (.25 lux) which is the ANSI-NEMA FL-1 standard.
I’m not sure why anyone is saying this light will throw XXX meters. I have the light in my hand, I have gathered my data and I shared it accordingly. I never made any mention of max distance in the OP or in any of my replies.
Please see post #8.
Luvlites: That is not my post. I never made any claim on max distance. We all know Chinese manufacturers embellish the data. Even Thrunite claims 700m and the TN31 does not achieve 120k lux. Why am I being nailed to the cross like this is the first time some data has been embellished?
Like I said, I have this light and I have gathered my own data and presented it truthfully. I was hoping that would be satisfactory for you guys. :~
