I dont know about my equipment, but even if readings are not nominally correct, they surely have some comparative value, and by these tests these cells are not better than my Trustfire flames, just some 200mAh higher capacity. (because Trustfire flames i regurarly measure just below 2000, and these I regurarly measure, with some exceptions, just below 2200, when discharging with 1A to 2,8V)
Yes, at some point I will do this, especially for the weird 1000mah cells.
Just that they are unwrapped and naked now, I am also planning to rig up a more robust holder someday to provent a naked battery from going poof during testing.
For anyone that may not know, I am a vendor for these batteries.
Before I start to dig to deep, I want to get a few things clear. Honestly, I don’t care about these batteries. I’m NOT defending them. I will simply stop carrying them if the quality is poor. I stock many brands of batteries and flashlights. I will not hesitate to pull these off the shelf as I have done with other items; if they are junk.
I am not on this forum to bicker. I really don’t want to point fingers nor do I want to tell somebody they are doing something wrong. I’m on this thread to get to the bottom of a flaw from a manufacturing vendor that I trusted. To this point I still do; with some uneasy doubt. We can only hope for the best.
The ultimate reason I need to get to the bottom of this is the customers!
I listen to my customers as these batteries where recommended by a few different enthusiasts. Now that we may have a flaw, it is important that all the customers that were sold batteries in the past had received what they paid for. It is a duty to do this service so I sleep better at night.
This thread has led me to purchase test equipment to run the batteries through. I want to do these tests per Samsung specifications in my own controlled environment.
Many people on and off these forums have dealt with me as a supplier. If you have, you know, or at least I think you know, that I do my best to cater on a personal level. This is how I run my small growing business and how I plan to keep it.
I will eventually come to a conclusion on whether I will continue to stock these batteries based on the test results. These batteries don’t seem to under or over perform more than any other brand that I carry. Nor has anyone ever contacted me and complained about the performance of these batteries.
Yes and no,
All i was trying to say is thats not how Samsung did there testing to come up with the numbers. My bigger concern it the Sony cell mixed in.
@ Troop, not wasted. You can buy shrink wrap tubing from any electronics/electrical supplier. Get some the right size, cut off the right length and apply enough heat with a heat gun to re shrink wrap it. It will probably bet a bit thicker and better than the cheezy shrink wrap these cells come with from the factory.
The HiMax batteries I bought from you on 7/2012 are still going strong and giving the rated capacity, some are even giving a little more than the rated capacity after several charge cycles.
I got this email from PingYi. Here’s what he told me and sent me to prove his case about this whole mess here.
We have the results of the survey,our batteries are all brand new and good,with samsung core.and the BBS post are our competitors,who want to destroy our company’s reputation, he is a Chinese, not American, intentionally destroy our brand, please don’t believe liar,here is a details,see email attachments.
thanks again,and your positive will be a great encouragement for us. If there’s anything I can help with, don’t hesitate to tell me.best wishes and have a nice day!
regards,
from pingyi.co.ltd
And here’s the picture he sent me that you can clearly see in post 30 here if you go back in look.
All I know is that some here I don’t think even know how to truly use their hobby charger or equipment. Most of the majority of folks that have these batteries like them. Mine all checked out good after charging and were right at 4.12 volts. They are working fine for me. Samsung makes some good batteries. Yes there are better batteries to be had, but you will also pay more for them typically.
ILF, I'm not sure what that picture is supposed to prove? It could be Ronald Regan's photo for all I can tell. As to your cells all charging to 4.12v, what does that prove as well? I have cheap UltraFire cells that all charge consistently to 4.2v, but they are still crap batteries. A DMM is not going to tell you that it's a good cell. Only what the voltage is.
I will still buy Hi-Max cells from Shane, as I believe he is going to test his cells in the future and I think he's a good and honest dealer. I'm not sure about buying from other sources, however. Nothing I've seen here from multiple sources inspires my confidence
Now I really dont understand what to make of it. Ididnt test all of my cells yet (only 4 of 12), but all have voltage drop to 3,5V in one minute or so…
SO thats nothing like results from HKJ’s original review of these cells. WOuld pingyi care to explain that? Im more than opet to all explanations.
HKJ recently did new review and now his results are little worse (but not as bad as my results - thats also mistery to me… and I doubt in all, me, HKJ, pingyi, my equipment, etc )
Here’s review from another member, of old himax (I mean older review), and curve is nothing like my (3,8V after 30 mins - thats why I bought these batts…)
This is from new review of HLJ, and they are still far above my measurements… 3,85V after 30 mins.
Zhats still science fiction for me because, as I said, I continually get 3,5V after only 1 minute or so (or even before).
SO, I dont know want to think abiut the but I wont by them until I make sens of it.
On same equipment I also test trustfire flames and some other cells and they have same or better voltage sag… I mean, if we presume the fault is in equipment, why get very smililar resultrs with TF flames (and these cells supposedly have much treater coltage sag…)
