Ah! Is that why many XP-E lights have a dark ring around the hotspot?
Hello anduril, welcome! Enjoy your time here. Thanks for the products tip.
Would have been if I'd not been speaking rubbish - the XR-E is the one with the ring. The beamshot on the left here http://budgetlightforum.cz.cc/node/224 is a truly classic example. It is not normally noticeable in the real world - just when white wall hunting.
I think I will have to wait to find out if these are really R5's. I've been looking to get something with a XP-G R5, but I would be afraid that the XP-E part is correct and the R5 part is wrong, rather than the other way around. It is a great price though. Just a couple of dollars more than just a R5 drop-in. I'm really tempted by the Skyray R5
http://www.dealextreme.com/details.dx/sku.32749
Not sure how much longer I can hold out now that I don't have anything in the mail.
Take care, the Skyray is an R4, R5 is just the name :)
BTW - my 5-mode R2@504B just arrived... wow. Now I officially have a lightsaber ;)
Did you get silver or black? I have the silver one and really like it. I just put a new driver in it so that now it is 2 modes with memory.
Which driver did you use, Ted?
Silver, but just because it had modes. No regrets though, it looks great.
My drop-in looks different, though - no labels ("super bright R2" or something)...
Can I safely assume that 4-wire, 4-segment LED is an R2, or is it not that easy? If not, then how to verify?
Mine had a label on the drop-in that said Super Bright R2 on it. There isn't really any way to tell by looking at the LED because all XR-E's have the same design, just different bins (except some old ones which looked a little different).
I swapped in this driver from Kai Domain. It is a Nanjing with the 4 stars on the back. I wrote a review at KD and was thinking about writing up something here as well (did it; you can read it here). I'm happy with it.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10243
They also changed the description from XP-G to XP-E for some reason, but someone posted today and said they had gotten an XP-G labelled R5. I might wait and see what people think of the cheap ones though now. Never hurts to wait a little (okay, it hurts).
Well, I gave in and got one of the cheap hosts today and am hoping for the best. I saw the first review of one of these at DX. The guy said it was really bright for 5 minutes before it burned out. That was a 501. So I ordered the 1-mode 502B:
http://www.dealextreme.com/details.dx/sku.35074
Plus this driver:
http://www.dealextreme.com/details.dx/sku.6190
Once I get it, I will measure the tailcap current and then probably go ahead and swap out the driver. I'd like a 1400mA multi-mode driver, but this 1000mA should still be brighter than the R2 which is also driven at 1000mA.
DX says it shipped today, so I should have a new light in a couple of weeks. Of course they said they shipped my last order too and then the status reverted to "packaging" a day later. But it said "Packaging by Air Mail" which I didn't know could be done, so I'm hoping it is actually on the way.
Nevermind. They seem to have broken the previous shipment into two, so this notice was for the second half of that shipment. The light itself shows "packaging" so it shouldn't be too long anyway.
Just to motivate you a bit - I'm waiting for your review, got one spare 18650 lying around :D
I'll definitely write something up once I get it. It's the waiting . . .
Somebody must have been listening. Today on Shiningbeam I see a 3-mode 1400mA driver. Looks like exactly what I've been looking for.
http://www.shiningbeam.com/servlet/the-133/**NEW**-3-dsh-Mode-Regulated-Circuit/Detail
It is the same model name as this 16-mode one from DX that is missing the 4th 7135 chip:
http://www.dealextreme.com/details.dx/sku.7612
So I just bought the one from Shiningbeam. My first order with them. I came close to getting one of their XP-G LED's but I already have one coming from KD plus there is a possible CPF group buy from Cutter for what could possibly be a more neutral tint.
That shiningbeam driver looks interesting. No flashing modes and not expensive either. Doubt there's room in a P60 driver to stack two of those to make a real 2.8A driver which would be interesting with MC-E or P7 emitters. Heatsinking might be a problem though.
Got the 502B today. I will write up a full review once I have a chance to test it out. My first impressions are good. The 502B looks good, came lubed already (too much, I'll wipe it all off and do it over), the clip seems strong, and the switch is firm, but the threads are kind of rough. The throat is way bigger than the drop-in so I don't see how it can have hardly any heat sinking. The 504B was a better fit but I put some pieces of aluminum cut out of a soda can to get it tight. I would need too many layers to do that here. I might coil up some thick copper wire and put that down there.
The drop-in is a single mode XP-G and says Super Bright R5 on it. It seems quite bright, but I haven't run it for very long. On a 18650 at 4.08V, I measured a draw of 1.2A at the tail, which seems reasonable. People have reported problems with the 5-mode driver burning up, so the 1-mode seems the way to go for now. I also got a multi-mode driver that I will put in eventually. The LED is on a white Cree board and seems securely fastened to the pill. I haven't taken the pill apart to look at the driver.
At first glance, this is a pretty good light.
Looking forward to see the comparison shots between R2@504B and R5@502B.
And yes, I'm developing luxoholism ;)
Well, here's a sneak peak. It is impressive. I had put a different driver in the 504B, but I partially burned it out doing some testing when I accidentally connected the battery the wrong way. So I have put the original driver back in for now.The 502B with the XP-G R5 is on the left and the 504B with the XR-E R2 is on the right. With freshly charged batteries, the XP-G is drawing 1.49A and the XR-E is drawing 1.18A. So not only does the LED put out more light, it is also being driven harder. It is probably close to 300 lumens.
XP-G on the left, XR-E on the right at 1/25th second:
at 1/200th second
at 1/1600th second. The P60 reflector does a nice job of focusing the hotspot, but you can see it is still bigger and it also seems more intense.
It might be a couple of days before I get outdoor shots for a complete review. My test range is badly overgrown with the fine spring weather. I will probably do some battery life tests tomorrow and get some pictures of the light and then add the outdoor shots this weekend.
Thanks for the shots! Take your time, it seems I'm not going to spend more money on flashlights anytime soon ;)
