Review: Roche F22 NW (Cree XM-L T6 | 1-2 x 26650 or 18650)
They are two different drivers, one with 3-9V input for 1 led and one with 9-17V input for 3 leds, that is clear on the Chinese forums.
Great review the !
Hikelite, do you have a link for the 3-9V version? Can it be bought separately? Is it a regulated driver?
Thnx
Any comments, can this light house 2 x of these King Kong Raised Tops?
http://www.intl-outdoor.com/kingkong-inr26650e-raisedtop-4000mah-liion-battery-p-370.html
Better recommendations? ICR or INR better for this use?
If you want to use 2x26650s in series , recommended protected cells.
Great review, bud! Looks like a real nice light. 8)
Do you have to use protected cells with this light? I have king kongs, IMR’s and INR 26650 batteries…will any of these safely work? I ordered this light thinking I could use one of these pairs of batteries!
I bought and just received one of these ROCHE F22’s with the optional extension tube. Like the OP, I immediately noticed that the second plastic sleeve (for using the 18650 calls) was absent. I contacted cnqualitygoods.com and was told that a second sleeve is NOT included. This is deeply disturbing…
  • No indications when ordering that a second sleeve isn’t included, even when purchasing the 2-battery extension.
  • No mention from customer service during our 3 email exchange, that I may purchase one.
  • Just “sorry, the second sleeve isn’t included”.
So now I’m forced to fabricate a sleeve just to use 2 cells.
Bottom line, cnqualitygoods.com won’t be seeing my funds in the future… that’s for sure.
Welcome to BLF Johnson! You'll love being here! There must have been some kind of miscommunication. Ric is usually very friendly and helpful. The second sleeve can be ordered separately for $1.5.
I just received the optional flat bezel ($5) and I think the light looks much better with it. This is of course a matter of taste..
As speculated before, the second extension tube allows usage of 4 x C cells. I don't have any NiMH Cs, but the light seemed to work also with alkalines, starting with 0.6A and quickly sagging to steady 0.5A (at TC).
TF protected cells seem to fit also in 2 x 26650 configuration, but are on the limit. Anything longer might have problems with tailcap locking out.
Appreciate the info.
It took me 3 emails to (politely) relay my concerns - only to arrive at being forced to pursue different options… for a problem that should have NEVER existed to begin with. Why no second sleeve when the optional extension tube is clearly specified during ordering?… and it’s not even listed in the ‘options’ on the product page. Worse yet, no resolution even offered, let alone, NOT being informed that ‘apparently’ I had the opportunity to purchase one… and have it shipped when the initial order was made.
Here’s the last of 3 email communications (please note: to get the second sleeve, they attempt to bait me into a second order - The way I see it, it’s like buying a car, only to discover long AFTER you take delivery, that spare tire is not included…. . Sorry, they lost a future customer over a measly buck-fifty piece of plastic.|():
[quote]
“Dear xxxxxxx
Each flashlight only equipped with one plastic sleeve.
If you want it, we may offer a free one to you next time.
2012-09-06
Best regards
Merry
CS”.
[end quote]
They know who I am, my concerns, and my shipping address. The solution is in their court.
Why censor our use of the term tacticool?
We should declare a day in September to be tacticool day, on this day we discuss all things tacticool and showcase the best and worse examples :bigsmile:
Tacticool would be a good brand-name for a small flashlight manufacturer :smiley:
Thanks Pok for giving the link.
So, I guess these would be OK for F22 :
http://www.manafont.com/product_info.php/trustfire-protected-tf-26650-37v-5000mah-rechargeable-liion-battery-1pcset-p-9538?rp=522815
They work fine in mine, but the length is "on the limit" (= tight) => manufacturing tolerances may cause them to be just too long causing tailcap lock out.
Can non protected 26650 cells like the king kong’s be safely used in this light with the extender?
Just the thing I would like to avoid…
Are all protected’s too long for this light?
I have only TF and Keygos protected 26650s and both of them work in my F22 (but are tight fit: Adding one 5c coin to negative end causes TC lockout)
I hope you have fun here, Johnson!
Short update: Bought 4 x NiMH C and noticed that 4C configuration with NiMHs is not good, since based on the voltage the light thinks its using 2x26650 and triggers the higher low voltage warning too soon.
=> Recommended configurations are:
- 3 x SubC with one extension tube
- 3 x C + dummy C with two extension tubes
Ps. I need to add that the new flat bezel felt really good in my jacket pocket. No worries about it ripping the pocket or anything. :) [The crenelated bezel has quite sharp edges!]
Very well, ordered this a while ago.
I see a tight fit as a pro = probably less rattle and no connection breaks in beater-use :wink:
No-fit is a no-deal for me.
Nice review.
I'm digging the soldered resistance wires, big time. Don't think I've seen that even on a pricey light.
springjuiceFoy
Incredible review as usual _the_, thanks so much for your hard work! Frontpage'd and Sticky'd.
