Yep, shipping’s been factored in, to anywhere in the world. I just don’t know how to modify the resistor inside to turn it into the 5000 lumens OTF light. Not sure if piggybacking it would achieve the outcome as we are talking about just a 0.05 ohms precision. (it needs 0.05 ohms to do nearly 5k OTF)
But if you need a 2.2k OTF floody light that can run literally forever limited only by batteries (well you can change batteries) and not worry about heat, this is it.
8000LM is just MFG rated,
You can image what will happen if you put an egg on the REAL 8000LM torch.
Especially it is in summer.
My friend has tested,3*18650.indoor,windless,9 degrees temperature.
upside down the flashlight,keep it still, at high power mode,about 67mins duration.
guess what happened?
the body climbs up to 54 degrees, extra 45!!! though the heat sink is good.
Anyway, the design looks good,nice moulding,at least not like a bad quality stuff.
and 7 led head looks awesome.
Applied to both 18650 and 26650,2 or 3,
X100 for $63.30 but no free shipping I don’t need the J18, I would assume the J18 isn’t that much different from the J12 with the KD beast driver in it. I really want an X100 since it would be different, mainly that it is much deeper reflectors so it will throw better. If the X100 had free shipping I would do it.
Rey indeed gives solid pricings. I got my X100 @ 119 shipped, 4 TF 26650 cells and 1 charger which I use for my laser and light stuff (single bay only, not the dual bay). Current lowest pricing is usd86 shipped for light only on another store.
And at least Rey got flashlight knowledge and know what he’s doing….so at least won’t anyhow push products and can provide basic support.
