With your icharger set your Nimh sensitivity delta to 2mv/cell in the settings menue, now and then i form charge them its like nimh balancing, its in the icharger nimh menue and you can use the same holders from the above link.
You have to use the "min/max" function on you DMM and have it connected when you charge. If it records a maximum voltage of 4.2 volt, the charger is doing a good job.
Hobby chargers usual terminates at 1/10 charge current, i.e. if you charge at 1A it will terminate at 0.1A. If you wish to terminate at a lower current, you must charge at a lower current. This will make the battery voltage higher.
A LiIon battery is NOT supposed to be 4.200V, this is a myth. The charge voltage is supposed to be between 4.15 and 4.25 volt and will always leave the battery at a slightly lower voltage. This can also be seen in all my battery test/reviews, the voltage drops when I stop charging.
The PEAK-button of the UT61E is quite confusing and i dont know how it works. Might be similar to Min/Max-button of other DMM's, but i am at loss here.
Connect the DMM, start the charge, the you press the PEAK button once and the DMM will record both min and max values. Press PEAK again to change display between min and max.
If the charger has noise in the charge current, the PEAK function may record to high and low values.
The only ways to get 4.2 volt on the battery is to use a very low termination current or charge to more than 4.2 volt.
You can do that with a voltmeter, AND it’s not a very good way to asses much from your batteries. If they hold voltage poorly then they are indeed bad. If they say ultrafire you know they are junk.
First, terminology; ALL the 4-button hobby chargers that look like the IMAX are CLONES, including the IMAX. There is a real (clone) IMAX B6.
There are people making and selling FAKES of the CLONES. These are cheaper, of poor quality, with problems with over/under volt charging, balancing, awful NiXX charging, and early death. *If you don’t have the ability to check it out……don’t go there.
If it’s eBay and cheap > it’s fake. :bigsmile:
If it does not SPECIFY it’s a ‘real’ one > it’s probably fake. But I’m not sure how much you can trust that from liars.
If you don’t have a decent storefront supporting the product, buyer beware.
FWIW Hobby King sells an original AND a fake/copy. They even SAY it’s a copy and are up front that it’s not as good a product.
Makes me wonder why anyone would buy this when it’s potentially dangerous.
Buy an Accucel-6, they are decent and essentially the same price.
So how do we charge a pack of NiCd (or NiMH) sub-C cells, say a 6s1p or 12s1p configuration?
i have the iCharger 206B+ , read the instructions manual , but the NiCd charging program has only a setting for charging current, not for number of cells (except for the Forming Charge program).
Does it mean that the iCharger doesn't care about the number of NiMH cells in series but simply charges and charges until the delta-V signal is triggered?
Cell count is ignored on this kind of charger, up to the limit of the charger. You can set the current and there is a setting for termination buried in there somewhere.
Thanks!
i found the setting “DeltaV sensitivity” and set it to “10mV/cell”.
imho on this kind of charger, charging NiMH in series (like a battery pack) is not the best thing to do. what if cell1 is 50% full, cell2 is 10% full, cell3 is half-defective, cell4 is 90% full. cell5 has a higher capacity than cell1-4, and cell6 doesn’t take a charge? then how will the termination work? This scenario is true for older cell packs.
The best scenario would be: each cell gets monitored individually, as in the balance charging of LiPo battery packs.
In theory, I agree. But, this is not lithium and it simply does not work the same way. NiMh simply does not charge in the same way as lithium. To charge it at all you HAVE to overcharge it, at least a little. There’s a fine line between overcharge (missing termination) and undercharge (early termination).
If you get real fussy you may have to tweak the sensitivity on a pack by pack basis. I have a Piranha charger that allows me 10 different settings so I use that most of the time. I hardly ever use the RC charger for NiXX anymore unless it’s more than 8 cells, the limit for the Piranha.
I think you can do something similar with the iCharger but my Acucell-6 is kind of a pain to program so I’ve never bothered.
Thanks for the assessment.
We never heard of Piranha chargers. What’s the official website of the manufacturer? Or do you believe it’s a trading company?
