If so, just first click quote and then open in new tab of one of the posts you want to quote and then do the same for the other. You then take the text in one of the messages and cut and paste it into another.
The problem is not the driver, it is the heatsinking. As I said in the other thread the it went down to low when the LED reached 200 degrees. This is already to hot.
LEDs don’t really go way down in output due to heat…yes there is some effect to the output but not exactly visible by the eyes.
I mean i have gunned triple XM-Ls at like 6A constant in the Sky Ray 3800 for about 30s. That is 18 amps bro, no joke and i was using 12V SLAs constantly charged to maintain the voltage (which affects current).
My TF X100 is about the size of the TF X6, same weight and same head mass etc. That’s about 3.6A at the tail. Granted it is way more efficient @ 3300L OTF, but heat wise shouldn’t be so far off. I could gun it for 20 mins, easy.
Wanna re-apply the thermal compound? There seems to be no anodisation in the thermal path to the external fins and 6061 mass to impede.
Keep in mind it took about 2 minutes to get to 200 and was still rising. Yet the fins were just barely warm. With out the thermal throttling I could probably cook on the flashlight.
Then there is something wrong somewhere. I have been playing with hot stuff like my SR3800 with DRY turbo driver and my 4 X DRYs with ice and dry ice and drivers till i got sick of the inefficiency. LOL! The heat should get out to the fins pretty fast, even though it is just aluminum. The same goes to the higher powered lasers as well……them diodes are much more sensitive to heat.
Actually there are 2 screws there. This should be a good enough design. You could check if that white MCPCB is getting way hotter than that immediate grey coloured ring of aluminum just beside the LED.
Thaicpf, good work from bro dong, as usual. (thermal measurements in there) If your temperature just rises a wee bit more than the stock X6, something is wrong.
Actually if you ask me, the X6 is like 30% more macho with more 6061 mass and surface area in the head portion than the X100. But alas no more space for another big shelf queen. (buying knives now)
