Thanks scaru. I figured since I toasted the battery housing, I might as well see whats in the charger. It has tamper-resistant torx heads… but… I have the cover off (thank you Harbor Freight). The wall-plug-in dealies seem to be plastic-welded to the case. I guess I could un-solder them.
some of the imr batteries can deliver10/15/ 20 amps ..I just salvaged some sanyos from a ryobi llithium drill pack ...i'm calling them lmr because i don''t want to get into what chemistries are being used these days ..[Too much battery research in the past few days]
..They are what they are ..able to be hammered on .. a bit safer perhaps and 1500mah....
Did you get the battery out? From my experience with making home made chargers they almost all run on 5 volts. If you can access the wires going from it to the charge board you could measure the voltage. If it is 5 volts then just use any USB power supply to power it. That is what I am using to charge lifepo4 batteries. :)
Oh yeah! Battery is out. The charger is also a wall wart, so no worries about power supply. On the back it claims output is 4V at 400mA. It has nice flashy little lights to tell you when it is 1/3, 2/3, full, and two different fault types. I realize the 400mA output will make it a slow charger. I just hope the charger does not rely on the (formerly affixed) protection circuit!
Do you have a DMM? If so measure the voltage that it puts out when charging the battery. (Disconnect the PCB) If you tell me that I might be able to tell whether it needs the protection circuit.
I don’t mean to be ignorant, so please forgive me. It was a different battery (one that I did not take out of the housing) that still had the circuitry involved. The only way I can attach the raw battery to the charger would involve making leads to get it to connect. I probably wont do that tonight. I truly appreciate all of your help!
If it was a different battery that is fine. That most likely means that the charging circuit is part of the PCB since 2.9 volts is not enough to charge a lion battery.
The charger has 4 terminals that correspond to T2, -, T1, and + on the battery housing. When I connect jumper cables between the cell and the + and - terminals, the charger shows a defective battery fault. I get the same fault when connecting to the T1 and T2 terminals also.
It seems like a pretty smart (but slow) charger. It is probably very safe when used as its meant to be used, but where is the fun in that? I think I will have to give up on using the charger. Oh well, I got a new 18650 and a way to keep the cats off of the counter.
LOL! Nothing worse than turning you back for a second only to turn around and find someone has taken a bit out of your sandwich. Our cat usually points a paw at one of the kids whenever I inquire. Fortunately, he is too big to defy enough gravity to get as high as the table or the counters so I only have to worry when I break the house rules about eating in the living room.
Welcome to BLF, Stuart. It is here where the fun is just as important as the flashlights.
If anyone wants to trade one or two of these batteries (unopened pack) for a new Redilast 3100, let me know. My Craftsman tools use the same batteries, and I wouldn’t mind a spare cell or two…
I plan on keeping the ones I have left. I believe the slickdeals thread contains a home depot inventory search. Maybe one in your area has some of these in stock.
If you are after high current cells I can also get some new ones for you. I just hate to see someone rip open a perfectly good battery pack when I have a legitimate use for these packs.
I can get just about any of the Sanyo, Samsung, Panasonic high current cells if that is what you are after…
Ok no worries. I thought you were going to also pull the others apart just for the cells, and didn’t want to see a perfectly good pack go to waste like that.
