You will notice this is the chart for 2000mAh 18650 AW and Efest /2250mAh SenyBor. The 2000mAh is equal up to 5A but drops off at 10A - too high internal resistance. The 1500mAh and 14500 are much better.
Yes, I noticed that. I just thought if the smaller one was good, the bigger one might be better. Half of the stated capacity seemed wrong, but if the internal resistance is too high, it makes sense.
Thank you for your trust to efest Yavi. Please just note efest batteries and chargers come with no MOQ limited. You can buy any quanity from efest.
efest imr 14500 700mah battery have flat top one and button top one. Which one do you need? Efest 14500 700mah flat top one is the best battery for L-Rider (lavatube) Mods. Stainless steel V5 VV Mod Kit is USD17.7/set but have MOQ limited for this. (MOQ: 10 set.)
Thanks, but I would only want a single Stainless Steel V5 VV Mod, if it cannot be sold sepparately, I would not need the 14500 IMR batteries.
[/quote]
Sorry, Yavi. V5 VV Mod can’t sell as single one. There are many Mods can use 14500 battery too, you can try L-Rider, the flat top 14500 battery is best for it. Well, sorry we don’t have that mod, you may try to find out from other suppliers.
If you don’t need efest 14500 battery, no problem, we totally understand. We still want to say thank you very much for focus on efest.
I wasn’t too happy with how the 18350’s performed from a consistancy standpoint, although I did cause some of the problem I guess by not cycling and checking them properly.
Thanks for the info ZW99GT, I will not use them in series, they are for a lavatube mini, I already have a pair of them and they are good to me, the lavatube on max voltage gets 3.5A from the battery.
The only other 18350 I have had were the ones from the ( R.I.P) bestinone, and after a few months they are not holding much capacity now, so it is time for new ones efest or AW.
I’ve been happy with their 18650 IMR in my Lavatube Chrome 2.0 (2.5A I think?). I don’t have any way to produce discharge graphs, but IMO they have matched or exceeded my AW. I’m sure the 18350 will do great when used alone.
Speaking of your mini Lavatube, I think you made a great choice there. I saw where you can get the extension cap to run 18650 as well, that makes it quite a diverse device. Would you care to share the link to where you purchased it?
