Test / Review: AW IMR 16340 550mAh (Red)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 12 min ago
DSC_2146
Official specifications:
  • Nominal Voltage : 3.7V
  • Capacity : 550mAH
  • Lowest Discharge Voltage : 2.50V
  • Standard Charge : CC/CV ( max. charging rate 1.5A )
  • Cycle Life : > 500 cycles
  • Max. continuous discharge rate : 4A
  • Operating Discharge Temperature : -10 - 60 Degree Celsius
AW%20IMR%2016340%20550mAh%20(Red)-info
This battery is a high current battery.
DSC_2145
DSC_2147 DSC_2148
DSC_2149
DSC_2150
AW%20IMR%2016340%20550mAh%20(Red)-Capacity
The battery works fine up to 2A, but is not that impressive with a 3A load.
AW%20IMR%2016340%20550mAh%20(Red)-CapacityTimeHours
AW%20IMR%2016340%20550mAh%20(Red)-Energy
AW%20IMR%2016340%20550mAh%20(Red)-PowerLoadTime
AW%20IMR%2016340%20550mAh%20(Red)-TripCurrent
In this test I do overload the battery and one of the cells looks like it is running out of power.
When calculating the internal resistance I used the voltage drop between 2A and 4A.
AW%20IMR%2016340%20550mAh%20(Red)-Charge
Conclusion
I am not that impressed with the high current capabilites of this cell, but because it is better than most ICR batteries, in the same size, I will rate it as a good cell.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
sb56637
sb56637's picture
Last seen: 20 hours 12 min ago
Thanks very much HKJ! Frontpage’d and Sticky’d.
MattSPL
Thanks for the review Smile
