The driver states 3A on the website, but in reality it will be closer to 2A? Is that due to efficiency? You used it before or read about someone who did? In reality you are right…2A might be more desirable in this setup!
It doesn’t seem like I would need to slave this setup, due to this driver doing the voltage regulating? Correct?
Yeah, I have used that driver before and measured around 2 amps unless you get above 12 volts. I think it just needs higher voltage to supply more current. I would suggest wiring it something more like this so you could turn on only 1 LED if you wanted to.
I would probably power it from 4 eneloops (around 6 volts at full charge) using a E1320 7135 driver. It is a driver that a member here(E1320) buys and reprograms so they have 5 modes going from moonlight to 3.1 amps. Then just repeat for the second XM-L.
Or if I got adventurous I might try to make one of the QTC variable output ones. QTC is a material that when pressure is applied conducts electricity, and more pressure is more conductive. With that it can be infinitely variable. What your are doing definitely has potential and sounds like a fun mod.
Very cool. Well hopefully this doesn’t turn out to be a complete fail! Hehe. If I can get 1000-1500 lumens out of it and 2 hours of runtime, I am sold. You think that is possible?
I bought several optics with various beam widths to see what I like best. Basically mix and match until pleased. They were $1 a piece, so I splurged a bit here.
I have tons of computer heatsinks around, so the LEDs will be very well cooled. I run a more “wide open” design so they get plenty of airflow.
The drivers themselves I worry about slightly, but I will probably find bits of aluminum and epoxy em on to be safe. I am hoping I have the newer revision of the drivers, which seem to overheat less frequently.
Shouldn’t matter. The switch basically just closes the circuit to allow electricity to move through (think of it like cutting the wire). If you cut the wire on either + or -, things still shut off. If you reconnect it, things turn back on.
I built a double XML headlamp thingy for my helmet a while back but, eventually took it apart because the heatsink, reflectors etc, were a bit heavy and cumbersome. If ambient temperature is low and you’ll be going fast enough on high mode, then, you may not need something that stresses your neck. I wish you luck with the build!
Newest plan thanks to some ideas here and at another forum. Basically adding dual switches like scaru suggested, and slightly changing the wiring to make sure that both batteries drain equally, even if one light is completely switched off.
This prevents the drivers from getting out of sync (meaning one is on medium, on on high, and being unable to get them back to the correct mode simultaneously), and allows even more adjustability. Aka I can cycle and have both on high, on high one medium, both medium, one off one on, etc.
Oops. Not sure how I missed this. Looks like it should work. I'm guessing the white lines are not wires or anything? Make sure you wire it up to test it before you do final assembly though.
scaru, the white lines were where the original parallel connections were.
y0bailey, the drivers I used were different from what you’re using however, I got ‘interference’ when both drivers were on ie, there was NOTICABLE flickering on low and medium modes. With one driver/LED was on, there was no flicker. Not saying it’s going to happen but just letting you know it possibly can.
Sorry, late to the party. This looks much like one of my first mods. I think the driver is a clone of the KD Super output P7 driver. Mine is still going strong after 3 years. I used it to power 3 xreQ5’s in parallel from 14 nimh cells 7s2p. I found that with 5 or 6 cells the low voltage warning would cut in before the cells were actually low. The build thread is on mtbr under same Rufusbduck. I used vistalite nightstick bits for lamp housings, wire, switches, batteries, holders, just about everything but the bulbs. Swapped the original subc cells for new 4/5 subc to get 7 in the space of 5. I like your idea for 2 drivers/switches. The drivers are not great for efficiency especially on lower modes. I think Subjohan at CPF did some testing with them. See this thread. Others have found them to be of inconsistent quality which is not surprising for a buck driver that inexpensive. Do what you can to avoid the driver sharing heat with the led as the driver has a thermal cutout. I know they do work but some people have had issues. Good luck
