Test / Review: AW 16340 ICR123 750mAh (Black)
Note: AW calls this battery R123A.
Official specifications:
  • 750mAH
  • 3.7V nominal
  • 16.62mm ( diameter ) X 34.29mm ( length ) - +/- 0.1mm
  • Overcharge protection at 4.35V
  • Overdischarge protection at 2.45V
  • short / over-current protection
  • max. recommended continuous discharge rate @1.5A ( 2C )
This battery is same length as CR123 batteries.
The capacity of the battery is about 550mAh and drops when the battery is discharged at to high a rate.
Conclusion
The battery matches CR123 in size and has an acceptable performance.
This battery gets a good rating.
Notes and links
Thanks for the review :slight_smile:
Thanks very much for the review! Frontpage’d and Sticky’d.
