Test / Review: King Kong ICR26650 4000mAh (Gold)
Official specifications:
  • Volt:3.7v
  • Capacity: 4000mAh
  • Size: 26mmx66mm.
  • Charge current: <=1a?
  • Weight: 95 g
The capacity is well above the marked value.
The two cells has the same capacity, but the voltage is not the same at higher loads.
Conclusion
The cells has a good performance, but they has a slightly different voltage when loaded.
I will rate this battery as acceptable.
Notes and links
Thanks for the review!
Thanks HKJ. I have been using a pair of these since they came out with no problems at all. Your capacity findings pretty well match mine. Cheers.
Thanks, HKJ. I have been very pleased with my KK cells.
Do you have plans to test the INR version as well?
I do have some on order and plan to test them when they arrive.
Thanks for your review,your a battry test monsta .I have four of these on the way from CN.
Jobs a goodn
DON…
Thanks very much for the review! Frontpage’d and Sticky’d.
