Today i used my colleges 287 rather than my 187 for some very basic mains checks, it damn well annoyed me having to wait for the silly little start up, heck id of been happy with my almost retired 70 series.
Is it user-adjustable ? … Can I use my 5.0002V as a reference and adjust the VC99 to read exactly 5.000V ?
This would be the ideal situation if there was just one “pot” to adjust to give the perfect reading … It would be a matter of which pot should I tweak ? … Unfortunately it would invalidate the warranty.
If you have a 4000 count meter and want to check the accuracy on the lower voltage scales you DO need another reference. 5V will cause the meter to switch to the next higher range.
I have been thinking of another way to get more accurate readings … My reference is known to be 5.0002V … If I connect my reference positive to my battery positive and measure between the reference negative and the battery negative with a high impedance meter , the reading with a fully charged 18650 would be about 0.800V … If I subtracted the 0.800V (or whatever) from the 5.000V then that should give me a more accurate reading than I get at the moment … I realise that this is a bit long-winded , but it would cost nothing extra to do.
I might not bother … I think that two places of decimals will be OK for checking my Li-Ion voltages.
I recommend the HP3458A. And for a better reference a Fluke 732 or 734. Add a Fluke 720A Kelvin-Varley divider to it to get any voltage you want (< 10V).
But then, that brings up the question of how do you know it is all working properly? A man with one meter never knows what volt it is. A man with two meters can know something is wrong. Better get three of each… I did.
Unless this is necessary for some other enterprise, a super-accurate DMM to measure battery voltage is entirely pointless. The Vout is variable depending on load, so any crapo-meter with a “battery” mode (like the $3 harborfreight ones, which btw can be calibrated inside) are going to be more “accurate” than a fluke.
It’s also why getting thick leads are pointless for measuring current, too. The thin wire spring inside a tailswitch is going to offer far more resistance than any DMM probe.
Nope, the thin wire spring is very short and has a low resistance compared to long cheap meter leads (which are almost always made of some thin stranded non-copper mystery-metal wire). But the real killer in measuring current is usually the current shunt resistor in the meter.
Yes, it requires another method, you can see one in my DMM guide.
That varies with range, usual you can expect between 0.3 and 1 volt burden voltage when the current is maximum for that range. Unfused cheap DMM's can be than the more expensive DMM's.
With auto ranging DMM, you might get a lover voltage drop in the low uA and low mA range, because they uses the same resistor as the high uA and mA range.
I.e. the high uA/mA has 0.3 to 1 volt burden, the low uA/mA has 1/10 of that.
[quote=agenthex]
It’s certainly not on the cheapest possible DMM available on the mass market today, so I can’t imagine it would be on a more expensive one.
[quote]
I am going on the specifications, not on a random test with a reference.
A 0.5%+3 specification means that 4.20 volt can be shown as anything from 4.15 to 4.25 with a extra digit the same specification will show 4.176 to 4.224
[quote=agenthex]
That as much as spec of accuracy as precision. I’ve never seen any meter be that imprecise.
[quote=agenthex]
My meters are very cheap ones (Sinometer M-830B) and are not auto-ranging … I have to use the 20V range for my Li-Ion battery measurements … The “accuracy” on the 20V range is quoted as + /- 0.5% of the reading +/- 2 digits … My voltage reference is 5.0002V at 72F and my meters actually read 5.00V … On a 2000 count meter , it isn’t possible to get any more accurate than this … I realise that the the actual voltage could be between 4.995V and 5.005V which would show on my meter as 5.00V … Being up to 5mV out , in the measurement of an off-load Li-Ion isn’t too bad really.
I was hoping that for up to £50 I would be able to get a meter that would read exactly 5.000V , but it seems that this is not possible in my low price range without tweaking an adjustment potentiometer (on a VC99) … It seems that perhaps I should just stay with my cheap meters as I can’t justify the expenditure needed to get the 5.000V accuracy when measuring my 5.0002V reference.
Do we need this degree accuracy (4.200V) for just checking Li-Ions ? … Perhaps not.
Yes, I know what the spec is, but context for why/how that’s meaningful is also relevant. 0.5% or whatever here doesn’t mean that for each arbitrary measurement of 4.20v DUT, the result will sometimes be 4.18 and then 4.22 a sec later.
In any, this isn’t particularly meaningful given that far more expensive instruments in far more professional settings are far less precise+inaccurate (often inherently, eg high freq sampling).
Similarly, I can’t imagine that the cheapo spring + various shitty contact points inside those typical 5cent switches in budget lights are as decent as the 18awg wire + stiff jacks on even the cheapest of meters.
Maybe if we’re working on the mars rover the last decimal point of accuracy would matter, but this is hardly it. To provide more context, not even the voltages inside intel chips running at >>1ghz are controlled to anywhere near that type of precision.
Getting a DMM that is guaranteed to show 5.000 is very expensive. My Fluke 289 (One of the best handheld DMM's) has 0.025%+2, with 5.0000 volt that would show 4.9988 to 5.0012 (Out of the box it will be better than that).
Going all the way to a 6½ digit (Fluke 8846A) meter you would get: 4.99985 to 5.00015 (With one year calibration).
