Upgrade A3 EOS @ 10440 and love it. UF 504B wasn't that comfortable to carry in the jeans pocket :)
MXDL 3W LED AAA Battery Mini Flashlight Lamp Torch from autoshop8810 :)
Small, quite sturdy, quite bright, super cheap, excellent for close range work, runtime is several hours... can't ask for much more.
But I plan to replace it with something brighter when I find a suitable (and cheap) torch.
iTP EOS A3 Upgrade Q5 which is awesome except that it's not a one-hander so it's tough to carry the kid, our bags, and light up the back door when we get home. i also carry a UniqueFire S10 which i'm gonna eventually keep in the car when i get a new light for work.
Altough a bit basic for a BLFer, Fenix E10 is my last EDC with its vanilla white light and forward clicky, along with my new iTp EOS A3 R5 which is always attached on my work badge.
Edwards J08 in 47s holster on my belt. Nice one handed operation with its clicky.
Qmini CR2 in my jeans coin pocket and rotate LD01, Revo SS, Qmini Ti 123, iTP A1 SS in my back pocket as backups. All of these are remnants of a time before I saw the light and started to appreciate the Beauty of Budget.
And you have nothing on a gold chain around you neck?
Rookie......
Can you make a review of that? Or a small comparison at least?
I don't have many AAA lights but there is that Black Cat I bougth to my wife and iTP is surely tinier than that.
The light is bright for its size but there isn't much hot spot to take pictures of so can't make a good comparison photo shoot for it. Black Cat has a tighter hotspot and this makes you feel it is brighter than iTP, but iTP shows itself in a dark room and amazes you with the broad light it emits. It's brightest setting is 95lumens but it isn't as striking bright (due to its floodier behaviour) as the 85lm camping output of Fenix LD25, which has a neutral R4 led and a tighter spot due to bigger smooth reflector.
Low light is very good for close work and still brighter than cheap $3 lights. The white is a bit greenish, but not blue at all. The lens is coated and bright, reflector is OP and shines a big spot without any artifacts.
It's construction is nice and has a quality finish. The chain it comes with is much heavier than the light itself, and being only 65mm long, you can hide it behind an id tag easily. The twisty action needed some getting used to and I still don't feel comfortable turning on with one hand. Mode changing isn't that much a problem if you have both hands. 3 modes, low-medium and high, are changed by quickly twisting the light of and on. No strobes, no worries.
After seeing how a high quality could be squeezed in such a small package, I definitely will buy one of the bigger EDC/semi-tactical iTP lights, maybe SA1 Eluma R5 too.
I have fell into carrying my Quark AA2 Tactical (R5). After the first few times I banged some anno off, I now treat it like a trusted tool instead of a pretty toy. I like the bright-per-AA package, the forward clicky and the super low, low mode.
Foy
pocket=itp A1 in a little pouch with a spare 16340 cell
edc belt=itp sa1 with 14500..spare 14500 in my pocket..
awesome setup for just about everything..
These days it's my TR-801, which I modded to XM-L and a 2,8 amp driver.
Ultrafire C3 (because it's crap and i'm not affraid to loose it), or Akoray k-109.
I have been carrying a SC60W since I got it a month ago.
"and why?" Well I'll tell you. :p Because it is as small as some of my AA lights and will run full blast for 2 hours (or a LOT longer at a reasonable setting). Add in its neutral-ly goodness and I've got my perfect EDC. Might be a tad bit large come summertime, but we'll see.
TrustFire F20, driver board replaced with a re-programmed NANJG-18. I like it because it is reasonably small and I can swap the 14500 for an ordinary NiMH or alkaline cell if I'm away from home and out of juice.
Im still EDCing my D10s (of varying conditions depending on where I go that day) and a V10R. All the other torches get to go out when I feel like it.
Seriously want to have a really compact 18650 EDC, these AAs just don't have the runtime/output for their size (changing batteries a couple times a week). My AA torches are all the size of a compact 18650 torch such as a Xeno G95... Only problem is finding one with a good UI. Seriously contemplating making one.. HAHA dreams on......
Maybe a bit old-school, by the time the weather got colder and I began to wear thicker coats with bigger pockets, last week I were carrying a Ultrafire WF502B with MC-E K drop-in. I love the size of a 502B and the power of 18650s.
This week I plan to carry a Maglite XL100. Its size is almost the comfortable minimum for my big hands. It throws well, enough light for everyday use, low battery consumption (due to low output :) ), has a good tint, has tons of features to play with, and I got 18 AAA's recently :D.
I have a XTAR WK25 flashlight in my pocket everyday. It takes 1xAA battery. Very small, but quite bright. I really like it.
Bought from szwholesale as a gift.
www.szwholesale.com/xtar-cree-105lumens-3mode-1xaa-flashlightxtarwk25-p-3858.html
I like that design Welcome to BLF, LW510 ;)
Aloha and welcome to BLF LW510!
Thank you Sashix & fishinfool ^_^
