If you knocked the wires off you can simply resolder the wires. If you don't want to do that then that light should work. I have the trustfire x6 which uses the same host. However it does run off of 3 18650 not 2.
Actually I was eyeing this one too, but I think the host is of similar design, but the DX version is much smaller. 58mm head compared to the X6’s 80mm head
Head is only 58mm, V2 is 62. 5 mode where as V2 is only 3 and not nearly as bright but
does have a slightly smaller hot spot. I have been waiting for someone to come up
with a good 2cell driver to mod this and a couple of others I have. Yes I did get it to go
with my X6 but was a bit disappointed with it. Pretty good for the money but not quite
the quality overall of the V2. Hope this helps.
One other small thing with the quality of the UF-X6S was if you look at the front you will
notice that the cut-outs on the bezel are all uneven which annoyed me. Or maybe I’m just fussy.
Nothing compares to visual aids… That’s a perfect pic.
the smaller X6S and light to its right are almost clone copies of a Surefire M3lT…
I never realized how small and the overall shape is nearly identical…
I have an X6 on its way. Its a beast in size…Hopefully a driver swap will bring out its
potential…Nice pics
On the up side, it does have a glass lens and an aluminium reflector but the pill
does not contact much of the body at all. There is at least a 1mm gap between the
pill and body with minimal contact top and bottom. At the very least it probably be have to
wrapped like a P60 to be driven any harder.
I really appreciate the response mazda96hatch. I guess DX’s measurements are correct after all. I’m disappointed this light can’t match the stl-v2.
DX isn’t always 100% accurate and the two lights seemed very similar in dimension. I have ordered the Small Sun ZY-T13, and considering it is only $24, I hope it is at least somewhat comparable to the FandyFire.
