Drop-ins
What's the brightest drop-in available? I've seen 5* Cree R2, 6* Cree Q5 and 7* Cree R2 (Wolfeyes light). As of now, what's the biggest/baddest drop-in on the market?
In "neutral white" it appears that the XP-G R2 slightly edges out the XR-E Q5 - is that correct? I realize the XM-L almost doubles the amount of luminous flux but I don't see that drop-in available.
Talk to me guys, I want to build a monster.
If you will a monster, you must build one by yourself.
Maybe buy a 3x, 5x, or 7x dropin and chanche the emitter and driver.
(i think, at moment 3 x XM-L are bright enough and have good runtime with 3x18650 ;) )
p.s. HERE is a monster ;)
Ok, maybe then what I'm looking for is an "affordable jr. monster." LOL
Where can I find a 3 XM-L light?
LOL Now that's a light!!!
That sucker should be able to light up several miles in front of him.
All that's missing now is a couple of wings and a 30mm autocannon... :D
The father of flashaholicism?
Yes, that´s the really brightest bikelight and "flashlight".
unfortunately he has removed some pictures.
Bikelight has 100.000 Lumen and flashlight ONLY 90.000 Lumen. LOL
Scroll up a little bit and take a look at distance shots. (oh, sunrise......ah, no, only a bike LOL )
Full link: HERE
(other projects are equally "crazy")
btt: don´t know, where to buy a 3 x XM-L dropin, sorry.
I can't read the name of the bike .. does it say Bovine ?
needs streamers
IIRC it says "townie"
Hi Guys,
I am exploring some options on a DYI light for the first time and this is what I am trying to do is find a single cell 16340 nice and small sleek host body with a simple drop or screw in with a 3 mode Hi/Med/Lo w/memory for a XML-T6. If someone has done this I would appreciate the links for gathering said items or would I better off trying to purchase one. Thank you.
Problem is going to be current. You will need IMR or LiFePO4 cells for the current draw - it would not be wise (or safe) to operate it with ordinary 16340 cells.
Solarforce L2m
Manafont XM-L T6 dropin
http://www.manafont.com/product_info.php/ultrafire-cree-t6-3mode-memory-led-dropin-module-42v-max-p-5178
I don't like the stock Solarforce switch and I don't like forward clickies for multimode lights - Solarforce sales can supply a different switch if you don't like the stock one (Or take the tailcap from an old-style Ultrafire WF-504B or a Uniquefire L2)
And some IMR cells. I've just got some from a cheaper supplier than AW on CPF, but have yet to test them. I have no complaints about the AW IMR16340s I have but they were a rather long way from cheap.
No idea who sells 16340 LiFePO4 cells. Which will need a different charger anyway.
And this guy is literally in the same state as me! omg!?
Don,
Thank you for the information you are a wonderful "Answer Man"
Regards,
Eric
