Just have to use decent cells and trust the systems in place.
Even TF Flames nowadays seem like a russian roulette.
For my TF Flames, well at least I did randomly pick some and test the capacity. I think that’s a good idea to do that.
Bite the bullet and spend 30 bucks for an entry level hobby charger, not that expensive anyway and it’s great fun.
Unfortunately most of the notebook power adapters are like over 18V, so need something to take that input voltage if you don’t want to shell out money for a power adapter. (assuming you have access to many unused/unwated notebook power adapters, have lots in my office :D)
I’ve got some explosive experience. If you’re wanting to build a charging box build it from wood. A 5/8” or 3/4” plywood floor and walls should be plenty. Make the box about 1’ cube with no cover this will contain the explosion and vent the blast upwards. Yes you’ll have a mess to vacuum up but no dangerous shrapnel from an attempted contained explosion. Box covers and the likes become projectiles. All explosions have to go somewhere with the open box it vents to the ceiling. Nice thing about wood is that fragments like to stick in the wood instead of bouncing off like metal or plastic containers. If you’re trying to cover an explosion use IV or water filled Ziplock freezer bags, but thats another story.
>>>>>>@ubehebe. Any idea how long the batt had been charging before it exploded? What the starting v was?
About 30 minutes. But it was cool as a cucumber when I felt it. There was another gray crapfire 14500 in the other charger slot.
No, I did not check starting voltage. That was in my salad days. I ALWAYS do now because I use all unprotected cells, so I’m always monitoring them to get a better idea of when to pull the battery before it drains too much.
When I first started with the li-ion batteries, I really didn’t pay much attention to charging. These bateries and chargers don’t come with any instruction manuals :-). I was vaguely aware that it could explode, but like everyone, thought it was rare and would happen to someone else. But surprise surprise! KABOOM!!!
Now that sounds like a good idea! All this stuff about sealed boxes. Like I said, I myself won’t be putting a a stick of dynamite in a sealed ammo box inside my house to see how well that controls the explosion. I wouldn’t put explosives in a sealed anything to control it. Of course, the box lid may pop off from the explosion and vent some of the force. But it’s like a battery PCB, I wouldn’t trust it to actually do that.
I’ll just skip all the contraptions and charge ’em outside, away from the house. If anything happens, no appreciable damage except to the charger and battery, PLUS minimal clean up.
I can’t stress enough, you DO NOT want to clean up that black gooey stuff. It is NASTY.
I like using the LiIon bags that are designed to handle a LiIon explosion:
They are frequently used by RC people, when charging their batteries.
But do not use them if you charger gets hot in open air.
I do not use these bags for regular LiIon charging, but in my battery testing, where I have been charging and discharging 24/7 for more than 1/2 year (I have never had any venting from the tested batteries or from any other LiIon battery).
I just got the temperature probe for my Turnigy Accucel 6 hobby charger and I think that might have prevented something like this (assuming the battery was getting hot before the explosion; this could still easily be a charger issue). The hobby charger can also be set to time out after some number of minutes and to only add a certain number of mAh to avoid overcharging as well. And it tells you the voltage and current the whole time it is charging. Maybe it’s not fool proof (you have to enter all those limits and change them for different types of batteries), but there are a lot of levels of protection that most chargers don’t have.
The problem with “Ultrafire” is that it is so commonly faked. PCB protection that doesn’t actually do anything is another problem with budget batteries. I like the idea of shorting a battery to test the PCB, but it kind of scares me, so I’ve never tried it.
The metal ammo boxes scare me because it seems like you’re asking for a short. Also I don’t have a secure battery holder for my hobby charger, just magnets holding alligator clips in place, so I want to be able to see what is going on and what is touching or not touching.
After reading instances where these type of failures have occurred I’m almost at the stage of thinking people using cheap chargers with *fire batteries deserve to have a scare! Now I know the possible outcome could be far more severe so of course I don’t actually wish that on anyone.
What is it going to take tho? A family burned to death in their house? That’s a very sobering thought and I really hope this makes people throw away any cheap cells, stick to the Panasonic/Sanyos etc and maintain safe practices.
It really is a shame as I believe good cells, well respected are very safe, the crap that people buy is going to lead to more and more restrictions
This is kind of off topic here but all this talk about explosions and crap got me questioning my li on batteries.
I periodically discharge my batteries about once every 3 months to about 2.5v to check the capacity on the hobby charger. Most of my batteries are unprotected. Is that too low to discharge the cells? I didn't think it was but since there's so many of you experts here, I thought I'd ask. Maybe I should be taking them down to 2.8v like HKJ's tests or even as high as 3.0v?
It depends on the batteries, NCR18650A go down to 2.5 but the sanyo 2600 go down to 2.8. As a general rule discharge them to 3 unless you read that you can discharge them further.
It was mentioned earlier in the thread. Given the number of sellers that advertise protected cells and then send unprotected cells, it doesn’t surprise me. I don’t know of any like that.
Thanks. That makes sense. I sorta knew that but I've been draining them all to 2.5v due to laziness. I'll start taking them down to 3v going forward just to be safe.
