Small Sun ZY-T08
137 posts / 0 new
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 3 years 4 months ago
Small Sun ZY-T08
This one came in yesterday. It’s not a bad light at all. The only negatives I see – the spongy switch, the fairly sharp machining edges just below the switch, and the ringy beam or artifacts around the hotspot. But these are all minor flaws. All in all its well worth the money. The beam is almost identical in brightness to the Small Sun ZY-T13. But it has pretty nice anodizing and machining all in all. It tailstands, and has a nice metal screw in bezel at the front of head. And it has a nice deep reflector.
Edited by: ILIKEFLASHLIGHTS on 09/25/2012 - 03:13
Essexman
Last seen: 15 hours 58 min ago
I’ve got one of those on the way to me, they do look good for the money.
Any idea how hard the driver is working the LED? I might do a driver swap.
Rusty Joe
Rusty Joe's picture
Last seen: 1 hour 55 min ago
What other throwers would you put it in league with?
ILIKEFLASHLIGHTS
It’s probably going to throw about like the Small Sun Zy-T13.
ILIKEFLASHLIGHTS
Ok I took some much better photos of this flashlight.
I just got done taking some beamshots. This thing is a thrower. I believe it will out throw the Small Sun ZY-T13. When I first turned it on outside for the first time, I was truly impressed. This thing has a pretty tight beam and is perfect outdoors.
These were all taken on manual exposure of 1.4 sec with a f/4 and ISO 400.
75yds approx
110yds to pool approx
Now these next 2 I wanted you to see both. I can’t believe how well it did at this distance of approx 350yds or so. The first one isn’t zoomed in as much. But they both turned out really well.
DON KIDIK
DON KIDIK's picture
Last seen: 9 years 4 weeks ago
Thanks for the insight.Looks alot of kit for the money.Mines ordered two weeks ago.
DON
ILIKEFLASHLIGHTS
Thanks Don.
I just compared this ZY-T08 to my ZY-T13. And there is no doubt in my mind that the ZY-T08 beats it very easily in throw at 100yds.
ILIKEFLASHLIGHTS
And just to show what my eyes seen comparing the ZY-T08 against the ZY-T13; the camera seen it as well. We'll do a mouseover on this one.  Same exact settings as above.  ZY-T13 mouseover and ZY-T08 mouseout
ILIKEFLASHLIGHTS
No I don’t.
But I would say it’s putting out around 600 lumens.
garrybunk
garrybunk's picture
Last seen: 1 week 3 days ago
Can you confirm the (2) 18650's are in parallel in this light?  I'd like to know about the driver current too, like whether or not it's direct drive on high.
Thanks,
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
ILIKEFLASHLIGHTS
garrybunk wrote:
Can you confirm the (2) 18650’s are in parallel in this light?  I’d like to know about the driver current too, like whether or not it’s direct drive on high.
Thanks,
-Garry
All I know is the batteries are stack side by side. I am just a dumb flashlight collector.
scaru
scaru's picture
Last seen: 5 years 1 month ago
Can you place them in the carrier and then measure voltage of the carrier?
garrybunk
garrybunk's picture
Stack side-by-side in the same direction (positive toward the LED end of the carrier)?  Can you trace the contacts?  Are both + ends of the batteries connected together (i.e. both + ends touch the same contact plate or strip)?
You could also measure voltage across both contacts of the battery carrier.  Wait a minute - I just checked and this version doesn't have a battery carrier.  So the cells just drop into the body?  Do they go in with the + ends of both toward the LED?  (That's what I assume which makes it parallel.)
Thanks,
-Garry
ILIKEFLASHLIGHTS
Both positive ends points towards the LED.
ILIKEFLASHLIGHTS
I’m guessing this thing puts out close to 45,000 lux. But that is just a guess on my part. It won’t beat my STL-V6 which I’m guessing is around 50,000 lux.
agenthex
agenthex's picture
Last seen: 8 years 2 months ago
Can you try it with only one cell in the light? If that works, then definitely parallel. Thanks.
Reading this makes you smarter: http://lesswrong.com/
Slewflash
Slewflash's picture
It looks like it did pretty well in the 350yd shots. This looks like a nice candidate for a mod (overdrive + dedome). Oh my, I think I’m obsessed with modifying now.
And as always, I love the SS bezel!
Slewflash
ILIKEFLASHLIGHTS
Slew,
For under $30, it’s one of the best throwers now I know of for the money. But again, it won’t out throw the STL-V6. It’s just driven harder. But if a guy drives this thing to 3.5 amps or so it would whip a lot of lights. It’s got a very good deep reflector.
ILIKEFLASHLIGHTS
I just did and it works perfectly. So now we know.
ILIKEFLASHLIGHTS
I might add that even the Xtar 18700 2600mah batteries fit in this thing. There a little snug. That’s what I have in it.
Slewflash
Slewflash's picture
Slew,
Hmm.. since I already have an STL-V2/6 maybe I’ll just chuck in an SST-50 4 amp driver and see how it goes. If it overheats into oblivion oh well, I’ve learned something new. But if it doesn’t then that’ll be awesome Smile
Slewflash
ILIKEFLASHLIGHTS
Slew,
I thought about dedoming this thing, but I’m afraid I’d mess it up. I have learned to leave well enough alone. That way I will remain happy with my purchase. I have the menatality if it ain’t broke, don’t fix it.
Slewflash
Slewflash's picture
At first I actually messed mine up, I used a pocket knife and a file, which in hindsight is pretty stupid.
If you have an ‘exacto-knife’ or something similar you can dedome it if you have adequate access to the LED.
I myself used a box-cutter (same as those american knives) and had to dedome while the emitter was still on the star, while it was still wired into the driver. So I was sticking the knife into the head to dedome it. I only had enough wire to move the star directly horizontal so I could chip bits off slowly.
Dedoming does increase throw, but it’s not such a major difference. It also isn’t hard, but if you ever do dedome it (successfully) you won’t regret it.
If you can get close access to the emitter then all you do is get a knife, slice off a large chunk of the silicone, then chip away at it until the surface is uniformly flat (also do it until you ALMOST reach the sulfur in order to take out most of the dome), then just polish it with some water and a soft cloth.
Slewflash
Silverbolt
Silverbolt's picture
Last seen: 3 years 7 months ago
Could I use CR123 batteries with this light? If I did, what would the differences be? How would it affect light output and run time?
agenthex
agenthex's picture
Probably can’t use cr123. Likely uses direct drive.
DarkSide
DarkSide's picture
Last seen: 4 years 3 months ago
Uh…Anyone interested in a really nice TC40 clone..lol I like the smaller or compact throwers
better and the paired battery tube. Im putting this one on my list..
Thought you guys would never stop with the XM-L witch hunt. Every where i look someones
tearing a dome of a brand new sparkly LED. And then buffer , didn’t someone wax their XM-L??
The de-doming effect is much more pronounced with luminous LED’s..Wonder what a P7 would
do minus the big bedroom window it has? Now, that you can stick a knife or fork into
ILIKEFLASHLIGHTS
Well I like this light so dang much that I ordered another one today from Manafont for $26.26 shipped. I told Rick today I know of no other light under $30 that will touch this one for quality and throw. The beam on this light is perfect outdoors.
old4570
Last seen: 5 days 36 sec ago
Looks nice , and looks to throw some as well ..
CR123 – Primary ? = 12v 18650 voltage is ? = series 8.4v Hope mine gets here soon …
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
ILIKEFLASHLIGHTS
Old,
Your gonna love it. I got Rick to buy one. I told Rick he will like this light better than he does the Small Sun ZY-T13. It out throws the T13 by about 15% roughly, and I think the quality is better.
agenthex
agenthex's picture
old4570 wrote:
Looks nice , and looks to throw some as well .. CR123 – Primary ? = 12v 18650 voltage is ? = series 8.4v Hope mine gets here soon …
THe light is two cells in parallel so 2 cells in their place will likely fry the driver if it’s designed for 1 cell operation.
jacktheclipper
jacktheclipper's picture
Last seen: 8 hours 21 min ago
I know a good lanyard wrap you could do to that light ....
What I do
