Review: UltraFire HD2010
:nerd_face:
Well, cannot get any refund from Lightmalls for this beat up sucker.
They told I could get “discount” for next order.
I left a message asking, how much would it be or is it a coupon?
sigh
I thought you bought it from lightmalls? Why are you blaming Tmart?
Because I mixed up these dealers. 2 posts Up I got my own pic and text Lightmalls :smiley:
Sorry.
Heh…cool. I just didn’t want to see tmart take the heat for something they didn’t do. :slight_smile:
Anyone knows of a holster the HD would fit in? Should be carried on a belt or MOLLE bags, either would be fine.
I ordered THIS on a whim, and considering the last pile of crap Ultrafire holster I had ordered a while back, I was VERY pleased with this new one. Well made, durable, and fits a variety of different diameter light tubes, up to the HD2010. It is what my HD rides in.
For the price, you can’t lose. :wink:
Thx, ordered
Well, ordered the FandyFire one from DX.
As well as batteries, and 18650 battery holders, as we just can’t get them here in NZ.
Under $60 for the whole order, totally stoked!
Will take some measurements and keep ya’ll posted when it all turns up.
My black HD2010 is here. Ordered on the 10th, arrived on the 26th, from Tmart. Only a few very minor dings on the body, which really aren’t noticeable at all unless you’re looking for them.
This is my first HD2010 and I’m very impressed with it. After modding it with a T6 3C I’m even more impressed. I’ve kept the stock driver in it for now which pulls a ridiculous 5+ amps at the tail from a freshly charged Panasonic 18650 (no doubt less than that of course when the switch is in place), but I’m planning on replacing it soon with something more suitable (should be an interesting exercise actually considering the format of the pill).
My only complaint is that the 18650 to 26650 adapter tube is a loose fit and therefore moves and rattles around inside the body. It’s easily fixed of course, but a flaw nonetheless.
If I have time this weekend, I will solder an U3 to this host. Copperbase should ease up the thermal sag but what do you Pro’s think:
should I get better driver for high power also or consider makin copper pill? (friend has a small lathe).
Or is it, that the copper star is most important and copper pill merely overkill?
Foy has the light output sag listed in his first post with the stock pill, led and driver.
Thanks!
Too bad I have no Lux meter…
Initial sag seems to be pretty high compared to what it sags later on.
Anyway, here is the pic:
Always a bit iffy to solder places with good heatsinking but this was easier.
There is plenty if extra in the Drivers cables, so I took LED aside, soldered cables first and made Thermal pasting (GC Extreme) & contact afterwards! :slight_smile:
Hi there! I received my hd2010 today from tmart. Package was slighly damaged and lamp had scratches but that didn’t bother me after three week waiting. I installed 26650 battery and wtf?? The threads of tail cap were really tight but installed tail anyway. Now I can’t get the tail cap off… Other thing is that only high and strobo modes are working. So now I must contact tmart and propably send the light back and wait another 3 weeks or what is their way of handling issues like this?
edit: first time I inserted battery the threads were tight, then tried 18650 battery and all modes were working, after that the jam happened when I put the 26650 battery back. Now the battery is stuck also in the lamp… I wonder do I have to broke the lamp to get my battery off or do I have to send the whole package to tmart…
the same thing happened to me just the other day. i thought i was screwed too. i was able to get it loose though by spraying wd 40. see if that works for you…
You can remove / unscrew the head from the battery tube and get the battery out.
Yeah!! Why didn’t that came in to my mind. Thanks!
Have a nice time here, kottero!
Let me guess: XM-L U3 from LED-Tech? :slight_smile:
My HD201 from Tmart sequence goes like this: Press fully to turn ON, always starts on High, half press to cycle through, Med - Low - Strobe - SOS. With flashlight turned ON, half press for at least 3 seconds on ANY mode and it will return back to high.
My modded HD2010 has now 120000 Lux 8)
…dedomed.
With: XM-L U2, 7135driver=3,7A, UCLp
before dedome it was 57000 Lux.
