Any chance to get international shipping with that price? :/
[/quote]
I've sent out a few packs of these to members here. Shipping is kind of a killer. It's @ $16 to the U.K. and I want to say it was ~$6 to Canada. I have no idea what it would be to Argentina. But yea, we're kind of lucky to have biglots here. I just picked up another charger/4pack plus another 8pack because they're working out so well.
Finally, after 40 hours or so (I've acually been testing these 8 cells since 2-23-11 which is 4 days of testing---man I need a life), the final break-in numbers are here and they are right where I'm used to seeing sanyo eneloop numbers at.
Break-In @ 2500mah:
1. 2476 mah -- 1.43v
2. 2444 mah -- 1.42v
3. 2439 mah -- 1.42v
4. 2454 mah -- 1.43v
5. 2456 mah -- 1.42v
6. 2450 mah -- 1.43v
7. 2467 mah -- 1.43v
8. 2448 mah -- 1.42v
Now all I have left is to do all of these tests I've been doing to the last 4 XXeloops (cells 9-12) and then I'm done.......for now anyway.:bigsmile:
You should make a runtime-test and bright measurement with one flashlight, first using normal Eneloops and then XX Eneloops. To compare if there is an increase in brightness (may be they have less internal resistance).
Very nice test, and very nice batteries. I just hope not to be drunk next to the computer or I will do the same
@ ezeqdb - When I'm done with the last 4 cells I'll try doing some kind of runtime test. I've never done one so I might need some advice as how to make the test fair and equal between the original eneloops (or 2nd gen eneloops=the colored ones) and these new xxeloops.
Here's some numbers on cells 9 - 12:
500ma discharge out of the package:
9. 1323 mah -- ICV = 1.43v
10. 1319 mah -- ICV = 1.43v
11. 1316 mah -- ICV = 1.43v
12. 1320 mah -- ICV = 1.43v
ICV = Impedance Check Voltage (after 500ma discharge)
Don't feel so bad - I have 64 AAs and 16 AAAs - and I give them all a break-in every twelve months, and keep a spreadsheet with records going back to when the cells were first purchased. (Feb '07 for the first 28)
Anyway - quick question - what are the voltages you've got listed next to your break-in results?
The 1000ma charge produced numbers very similar to cells 1-8 in post #15 above. The numbers are very constant. Not one stands out from the others which is very good and typical for Sanyo Eneloop batteries. You gotta love 'em!
i think fishinfool was hit by lightning as a baby ..
Two guys looking under the hood ..
one's looking at the 440 hemi
and one's looking at the interstate battery
You have to understand How much work fishinfool has put into such a great database of batteries and how much time it takes to do all this ....
So when he hears there's a new Eneloop Battery available ...he starts thinking ..Oh goody A battery that will keep it's charge for a long time ..WHEW that will save some time ..!!!
