Very good video. Thanks.
Thank you so much, I really appreciate you sharing this. I was so impressed with the P-60 Nichia you did it was mind blowing. You transformed one of the worst beams ever to one of the nicest beams I have ever seen.
Thanks alot for that tutorial!
From now on I will read all your posts with your voice in my head
I did almost the same on a P60 reflector (I used hairspray instead of clearcoat), but the problem I had was that I always had a few bigger “drops” in my “spray-stream” wich resulted in a few bigger dots on my reflector…
Do you know this phenomenon? Is it because the spray-can I used had a bad head, that did’nt vaporize the hairspray liquid good enough? Or do you think hairspray is just not really suited? (of course it is not_ really_ suited, but I thoght it might do the job )
I doubt that a few bigger dots will matter. After all that is the point of making it OP. ;)
Haha, you da man, Old, you da man :bigsmile: :bigsmile: Great vid!
Would be great to see before and after beam shots, just to see how much throw is affected and how much it smooths beam down
Whe I first heard about stippling a reflector , some of the practitioners actually damaged the apeture of the spray can to achieve a coarser spray . Others became experts at pushing the button just hard enough to control the coarseness of the spray pattern . Some even felt that a nearly empty can produced the best spray pattern .
I think the hair spray is not suited for the job and the spray head will not give a coat like a paint head will.
Yep, I probably need to do that, with the next Maglite D build. Guess I had better write it down, before I forget…
What am I supposed to remember again?
LOL
For anyone that lacks "holy underwear" just hold it with your hand and wash it off in the sink. That's what I just did a few minutes ago on one of my reflectors. :D
Nice Video Old-Lumens!! Great info.
I thought I could smell paint earlier!!
Many Thanks!!
Thanks OL, I’ve always wanted to see this as I have a light or two I’d like to apply this treatment too.
Very informative, thanks for sharing.
lol :bigsmile: Who are you? Where am I? :bigsmile:
OK, don’t know where to ask this stuff but will try here: have someone tried SMO reflector with XML and de-domed XML with OP/stripple reflector (same reflector or very similar size)?
I haven’t seen any threads on it. I am going to do SMO and Stippled on the Nichia 219 and then on an XM-L T6, but I don’t plan on de-doming anything, unless it’s by accident. The 219 should be done this week-end and the XM-L might be a couple weeks away. I can’t do lumens testing, so it will just be beam shots on the same night, in the same light.
One thing to be aware of when using this technique on high-powered, heat generating lights is the tendency of the spray to yellow…
I did this tonight, but the outer part of the reflector smooths out every time (did it twice).
The center looks good though, I wonder what I’m doing wrong, maybe need more distance?
my bad…
it just depends on the side from which you look.
from the side, it looks like it`s smooth towards the wider end of the reflector.
like in my first pic (even though, in the picture it looks more stippled than in person)
but when I checked it from a different angle, I could see that it was stippled all over the place, as seen in my next picture:
anyway, all is good now!
Can someone try to stipple only the inner half/part of the reflector?
You should try it and report back to us.
I don’t have any spare reflector I can only try it in my P60 drop-in or HD2010 Wish I had another SMO P60 reflector :~ I only have 2 spare switches that came with Xeno and ITP, and a bunch of o-rings :bigsmile:
