Hehe, it looks like itll dissapear after second dive
I wonder do all budget diving lights corrode like this. XTAR lights?
That MCE 2X18650 light (Magicshine?) about wich we talked a lot here?
DX just today listed this flashlight, price: US$ 100,70
http://dx.com/p/trustfire-tr-df003-3-x-cree-xm-l-t6-3000lm-5-mode-white-light-diving-flashlight-black-2-x-26650-155784
My friend bought this lamp and took it to local shop for testing. Max output was 1063 lumens
https://dl.dropbox.com/u/16735593/trustfire_tr-df003_jarmo%20(kopio).png
I was going to buy same lamp, but seeing those test results changed my mind. I think that it would be good result for one led light but not 3. Tested current at max brightness was about 1.3A.
Is that unit somehow broken or are leds used approximately 30% of maximum power for some reason?
I have my TR DF003 about a week now. This lil diving light was clocked at 1440 Lumens a number of times by me. Even without a meter i can say with certainty this is no 1000 lumen light.
The numbers dont exactly jive as well…3 X XM-L 1063 Div by 3 = ?
Nooooo way
Welcome to the family, ColdWater Diver!
Anyone who has dived with this flashlight and did not have problems?
I’ve tried today at home under water and I have seen that sometimes does not respond to changes in light mode when turning, tomorrow I’ll go to a store to buy O-rings
quality and diving’ll try it next Saturday.
Greetings from Barcelona
Welcome to Flashoholics Anonymous, shackleton!
Has anyone changed better driver into this flashlight to get more light from it?
When I make deep dives, I need as much light as possible, but those deep dives are not very long. 1 hour runtime would be enough at full power. Also it would be nice to have lower power modes for longer dives.
So what is happening here? Is it the salt water dissolving the aluminum?
No. It's not a problem of salt, but the salt partecipate to what is happening.
What you see there is typical electrical corrosion happening underwater: electrolysis. I work with ships, and know well enough the problem.
When this light is switched on, the ground (or -B as you prefer to call it) is from the cell bottom to the tailcap, and tailcap fully tightened makes contact with body, so also body is grounded, the ground then goes to driver and led. The + pole from cell goes to driver and led. The circuit is closed and the light is on. There's no difference of electrical potential between body and tailcap and no corrosion happens.
But when the light is off, the ground is only the tailcap. Not being fully tightened means no contact with body, so body is not grounded. So what happens next? Happens that + pole goes through driver and led, and to body. The circuit is open between tailcap and body. That is easy to figure out, anything that can electrically connect body and tail, will let current flow, and light will switch on. Well, when the light is on air, the air is relatively dry and a very bad conductor, so no problem. But when immersed in seawater, the salt rich seawater act as an electrolyte, and happily flows electrons. The body and tailcap are acting as anode and cathode, the cells supply the power, the seawater is the perfect electrolyte to the job: the anode release electrons and the electron-deprived metal corrode and dissolutes in the water (pitting), the cathode receives the electrons and in the area builds up a layer of whitish minerals from the water.
As soon as the cell can supply current, the corrosion will not stop, untill the cells are depleted or all the metal dissolved. The higher the current rate the cells can supply, the faster the corrosion. The anodization prevents the aluminium from corroding in air atmosphere (anodization is an induced passivation, which is electrically inert in air), but can nothing when in seawater, because the chlorides (salt) dissolve the alu oxides forming the anodization.
The next bad part of the figure is that there's no real solution to this. The use of a mechanical or magnetic switch (rubber booted) and keeping body and tailcap grounded (electrically connected) will anyway slow the corrosion rate by an enormous margin, eliminating the current dispersion.
Note anyway that alu in seawater will corrode, and any scratch to the anod is a good starting point.
Note also that most frequently used alu "light alloys" are not suited for seawater immersion, because of copper content. The alu alloys for marine service are special alloys low on copper and high on magnesium and manganese. Can you bet, they are more expensive than other "normal" alloys for terrestrial application, so I can hardly believe a flashlight producer will invest in these. Much easier to use PVC or other high tech "plastic".
Hey Rockspider,
Wouldn’t it be possible to isolate the grounding from the bottom of the batteries, and connect it through a wire to the circuit board? Maybe there is not enough space inside the body for the wire, but maybe some kind of isolated flat wire?
I agree that using aluminum is a problem in itself. That’s why you don’t see many genuine diving torches in this material.
I know it is off topic, but the Danish company Wiseled makes some high quality underwater flashlights, who apparently have solved all these problems. The reason being off topic is, that they are unhealthy expensive: http://www.wiseled.com/flashlight_adventure_diving.htm
Peter
Thanks rockspider for the great explanation!!… RE: electrolysis and electrical potential.
thanks!!
Re: Olderman
Yes making an internal wire connection between battery minus and driver would solve the different potential issue between body and tailcap, but anyway the tailcap must always be well tight in order to keep the same potential as body.
Re: Kramer
Thanks
I know that this torch is not sold by DX alone, but they are one of the big resellers, and they are official members of this forum.
What is their explanation of this Trustfire TR DF003 having those big issues? Maybe they should ask the company Trustfire or whoever is behind the design of it.
All we see is an ‘ooops we just correct the lumen output in the spec’s’, nothing else. Maybe I just haven’t read the official statement, but there should in my mind be some kind of statement from the supplier / producer after this kind of blunder.
Are you all satisfied with your money back, and that’s it? Wouldn’t it be fair to ask for an explanation? Wouldn’t it be nice to hear, what they are going to do in the future? Are there going to be an updated version with all problems solved?
Am I too demanding? :~
Just got this light and took it to a dive in dark water. The beam seems to be too scattered for these murky waters but I’m still going to try modding it. Ordered a new driver for it that should give 3 A of current and also a switch and a rubber boot for it. I’m going to install the switch to the tailcap and it will still use the body of the light for connection but the switch will cut the minus from it when turned off. So electrolysis and switching modes should not be a problem
We’ll see if I can make it waterproof and boosted up…
Ok, I just ordered one of these torches online and I am now reading all of this bad news about them. (FML)
I guess that is why the trustfire website doesn’t even have them on their website and removed them from Amazon.
Anyway, I have no choice but to try to modify it and give it a go. First on the list are new O-rings. I will probably just buy viton o-rings. Can someone please tell me the two different sizes?
O-ring lubricant, I will opt for aqualube or molykote-111.
I need to know how to put in a tail cap to stop the corrosion on these lights. Whoever figures this out please share some pics!!
I agree. They might as well slap some black paint on the front of the lens while they are at it. Proof that the people in the design dept work on a different planet than the ones that do the actual testing.
I just took off the reflectors off mine. Even though the LED’s are 2 inches in past the bezel it still gives a nice wide beam… Not very bright at all but 2 are good enough for my GoPro set up which is why I need to find a way to fix the corrosion issue.
All these diving lights are moderately driven so they run longer on a dive. With the Trustfire cells provided in the kit, I get exactly 2a at the tailcap. And yes, it does give a nice beam even though the reflector is set back very far.
