Thanks cainn! I'll have to order a couple of these! Can you measure resistance of the original switch and this one for comparison?
-Garry
-Garry
Thanks for the info cainn. :bigsmile:
To be perfectly honest, at this stage I don’t have much confidence in my ability to accurately measure resistance in something like a tail switch. What I did do was take some lux readings with the original switch and the Solarforce replacement. 152 with the former and 188 with the latter, averaged over 2 attempts. I started with the original switch, took a reading, swapped in the Solarforce switch, took a reading, swapped in the original again, took a reading and finally swapped in the Solarforce switch again, and took a reading. The difference was about the same each time, so the averages above are an accurate indicator of the difference (rather than just the average of 2 wildly different results). This was during a ceiling bounce, with the light tail standing in the exact same spot each time, about 2m from the ceiling.
Any idea what diameter those solarforce switches are? I'm wondering if I could just get a 5 pack of these Ultrafire's from Manafont (21.27mm in Manafont photo). Then there's these Uniquefire's (20.56mm in Manafont photo). I have some of these basic switches, but they are kinda junky and are probably higher resistance than the other two options. I would have sworn I'd seen some "Ultrafire High Current tail cap switches" at Manafont too, but I can't find them now.
Is there a reason for using the Solarforce switch? Is it because of the retaining ring piece, or is that not needed? I also don't have any other tail cap boots.
-Garry
Well I finally received custom pill and after some painstaking sanding and few “touches” with hammer this is final (almost :bigsmile: ) result.
Custom alu pill with opening for standard 17mm driver
I slightly miscalculated things so plunger on spring provides reliable contact with battery
Reliable negative contact is made with wire sandwiched between battery tube and pill part. Not pretty and elegant but it works reliably.
Holes for wires were bored at an angle
I still have to make some real world outside testing but so far things are looking promising
Looks nice chief
The Solarforce switch has a diameter of exactly 20mm, and measures about 24mm from the button to the tip of the spring. It’s the ideal size really because it’s only a touch shorter than the complete original setup. Using a switch that’s much shorter than that might result in decreased output due to exerting less pressure on the battery, although this could be overcome by soldering a bigger/longer spring to the driver (or even the switch itself for that matter). The retaining (screw-down) ring piece is important as you can’t use re-use the original because it would create a short between the spring and the body (making for an always-on flashlight). You could try to insulate it somehow, but it also has to make contact with the switches outer ring so it would present a challenge.
I’m not saying that you can’t make some other sort of switch work for you. I’m certain that it’s possible. It’s just that you’d likely end up doing something different from what I’ve done. I was simply lucky in the sense that I already happened to have parts laying around that were suitable.
Just look for 16mm/8mm (or 16mm/7.5mm) rubber/silicone tail cap boots with an inner button (not the recessed kind that IO sells). These ones are probably suitable, although they are currently sold out.
The other thing you could do is pull the original switch out, look at it, look at the tail piece, put it back together, think about it, pull it apart again, run through some hypothetical scenarios, scratch your head, become slightly irritated, put it down for a while, forget about it, pick it up again, and then hopefully come up with an entirely new solution using a unique collection of new and existing (possibly modded) parts. Then you could come back here and post about it!
Great stuff chiefinspectorfinch
Thanks cainn for that info. Sounds like I'll just get a couple of those Solarforce switches and hunt around for some tailcaps.
-Garry
Found more 16mm/8mm tailcaps at KD so I placed an order. Ordered 2 of the Solarforce switches too (and it was really hard to resist throwing in a Solarforce body too). I know it's a Chinese Holiday so I expect delivery to be delayed.
-Garry
Got 26650’s in from led-dna today and they were at 3.67v and at the tail cap they read 2.25a which is about as high as i even seen it. Have to charge them tomorrow and see if they sill put this thing up to 3a+. If this thing don’t get brighter then i might have to call this a waste of time without a better driver and positive spring along with other things maybe.
Put it like this built a xpg2 drop in for my l2m with a KD V2 2.28a version and it is brighter the the eBay 57mm head light. Kinda not happy with the ultraOk. Very happy withe xp-g2 though like the he k out of that build. Might have to try a different emitter or style to see if it is better or give it away to a non flashaholic.
I’ve seen 3.56A at the tail from a freshly charged Panasonic 18650. Immediately afterwards I put the same battery in my HD2010 and it was delivering 5+ amps so despite my best efforts there’s still a significant degree of resistance somewhere. But it’s not a big deal because I don’t really want any of my XM-L lights to be pulling much over 3.5A anyway, so I think I’m done modding this one.
In the end this has been totally worth it for me. I was convinced that I was going to end up giving this light away but I’ve changed my mind. It’s finally hanging with the big boys. It’s certainly not winning, but it’s definitely up there. After putting all this time and effort into it, making it better and making it my own, I’ve grown attached to it, and am subsequently deriving increased enjoyment from using it.
That cell at 3.67v is pretty well fully discharged. You should see a huge gain in amps from it when it's fully charged! Be sure to report back. What brand of cells are they? (I haven't tried any 26650's in mine since I haven't gotten the LED properly heatsinked.) I would like to hear from ceHowardGS about his cuz I know he's using 26650's and hasn't done anything to the LED star/pill connection.
-Garry
I finally got the 26650’s charged took probably like 12+ hours. After that check the current again and now I am over 3a’s and you can really tell the difference. The light is definately brighter! Ya finally! But the battery us to short for the light doeant want to stay on. I put a penny on the negative side and it stays on but im sure that is not a good way of doing it!
Ps now its brighter then my xpg2 driven at 2.3a :bigsmile:
I think the cels are the king kongs they look like the ones HKJ reviewed. I got them at leddna for sweet price
I probably should have mentioned (especially to garrybunk) that I’m using protected button-top 18650’s, which are 68.8mm long. In other words, my particular method of getting a Solarforce switch in the tail might not work too well for anyone using significantly shorter batteries, unless they also put a longer and/or tougher spring on the driver and/or switch itself.
Could it do 3xAA ?
The inner tube diameter is about 26.5mm, so there’s no chance.
EDIT: Would be great if it did though. I’d love to see something like a Cyclone C88 with a 55+mm head. In fact it’s tragic that a HD2010 head doesn’t screw onto a C88 body. It’s not far off really.
Concept light:
Oh that looks Swwwwwweeeeeet!!! I want one!
Oh, and thanks for in the info on the Solarforce switch. I think that spring on the driver needs beefed up anyway. I'm about 2 weeks away from having the switch & tailcap parts.
-Garry
Recv'd my Solarforce switches today - 8 days from order and ordered during the Chinese holiday! My first experience with Solarforce. Also received my aluminum heatsink pill "insert" from a generous BLF member the other day. Now if I can only get some free time to work on this light!
cainn, I should be ok. I also use protected 18650's and a raised-top King Kong 26650 (which is a bit longer due to that "raised-top").
Just brought over this photo I've posted previously. That plastic disk is 0.50mm so this raised-top cell is 68.05 - not that much longer.
-Garry
