XM-L - Which light drives it the hardest?
26 posts / 0 new
Trancersteve
Just before christmas I purchased a Kaidomain 5 mode XM-L 3.7v-4.2v P60 dropin. It is a a brilliant dropin and my brightest light to date and sits nicely in my L2P host.
This dropin draws  2.2amps from a 18650 cell.
EDIT: Was not using a fully charged 18650! The reading from a 4.2v 18650 is 2.9amps
My question is where should I go for more light output from a XM-L emitter? I know the XM-L is capable of handling a higher current than 2.2amps.
Which light out there is driving the XM-L the hardest?
Thanks for your help
(I feel like the quest for more lumens is grabbing me! :D)
I wear my sunglasses at night.
Edited by: Trancersteve on 03/03/2011 - 18:00
brted
brted's picture
Last seen: 3 weeks 4 days ago
Check out Don's 40-meter picture thread. The Manafont drop-in looks like a champ. Non P60 lights will be able to drive the XM-L harder and keep it cool enough to stay bright, and the KD C8 seems to be a favorite, though I don't have one.
Don
Don's picture
Last seen: 2 years 3 months ago
The P60 is great if you already have a light that can take one. If I didn't already have several, I'd look at one of the C8 type lights which should do a better job of shifting heat. These LEDs are pushing the cells hard, better cells may well make for more output.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Budgeteer
Budgeteer's picture
Last seen: 9 years 4 months ago
I have 3 from KD 2 bough separately when they were up for grabs at 13$ each 1 with host and 2 from manafont. The least hard driven draws 2.94A at tailcap. You sure you have batteries up to the job?
The sony cells i scavnged from a laptop don't want to go beyond 2,4A draw. Thew new cells i have easily pulls at least 3,5A
anyway the sweet sport for an XM-L is around 2,4A to the emitter. But for a wow factor a few bursts at 4A can be fun! Dual 18650 advised.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Trancersteve
Thanks brted I will have a look at the Manafont drop-in
Christ! I just checked out Don's photo thread. Firstly great work Don! Secondly that Manafont drop-in looks incredible! I definitely will be ordering one later tonight.
On the subject of the P60 format: I do like the format I have 5 hosts that accept them but I understand that they are never going to be great at dissipating heat.
I am open to new lights/hosts if need be.
Budgeteer - I am not sure and you have me thinking about if my cells are up to the job of delivering the kind of current I want. The cells I am using are Hi-Max 2600mAh protected cells - these cells were formerly branded as WOW cells and performed well in tests. I was told by the seller that these are exactly the same cells as the WOW just rebranded.. not so sure about that now.
What cells are you using Budgeteer?
pounder
pounder's picture
Last seen: 1 year 11 months ago
yeah 2.2a is low for the kd drop-in..mine is 3.2-3.3a depending on the cell..it'll measure 2.2a when the cell is at 3.8v..some of my cells only manage a 2.8a on a full charge so internal resistance is higher in some cells..i've got a few cells that manage 3.2a so I just stick with them for the higher powered lights..
Nautic
Nautic's picture
My KD xm-l drop-in draws 3 amps
Cheap quality is good - Expensive crap isn´t
Andi
Andi's picture
Driver from Manafont P60 XM-L dropin in a Brinyte C5 XM-L = @High=4,6A
(only the driver from dropin!)
and KD C8 XM-L:
g
Don
Don's picture
That's more amps than most 18650s would be happy with. Myself, I'd only use IMR cells for that.
Andi
Andi's picture
This are flamed trustfire (rechargeable/protected) 2400mAh ~1,5 years old from DX.
I have bought newer one´s(the same), but there protection trigger. (maybe trustfire chanched something)
Don
Don's picture
Twice the capacity in mAh as mA is the usual recommended limit. I don't believe (with good reason - like every one I have ever measured) the capacity claims of any lithium cell.
I have pulled way more than that (like 12 amps from an 18650. Pulling that from multiple cells in series is asking for an explosion) from several cells - in single cell lights you will probably get away with it - but don't bet anything important on that.
With multiple cell lights be afraid.
Very afraid.
You will probably not have bad consequences but don't come crying to me when you do.
Personal advice. If it uses more than one lithium cell in series - i.e., if it needs more than 4.2V - be careful.
Trancersteve
Argh! The cell I was using for that initial test in my first post wasn't fully charged.
With a fully charged WOW 2600mAh cell I have a reading of 2.9amps with the Kaidomain 5 mode XM-L 3.7v-4.2v P60 dropin.
srfreddy
Last seen: 10 years 4 months ago
Red and Black Trustfire 2400's are 2450 mah. AW and Redilast 2200's are 2200, AW 2600's are 2600mah, you get the point. But they're so goddamn expensive.
pipopopo
same with the new bleu trustfire 18650s, 3.5A max higher than that=> protection
I can get imr18650 batteries for 3-4 euros maybe I should buy a bunch
(offtopic how do I get quotes in a frame )
Match
Match's picture
Last seen: 6 years 9 months ago
Just hit the quote button underneath the post of the person you want to quote.
You can also just type the [q.u.o.t.e. = person's name]  "your message here" [/q.u.o.t.e.]
Just remove the periods in the word quote.  I had to add them to get the code to show up. Then you can do neat things like this:
pipopopo wrote:
Match is the greatest!  I need to send him some beer!
Awww shucks....you shouldn't... (make it a stout) Beer :bigsmile: Beer
frills
Last seen: 10 years 3 months ago
I recall that those Trustfires with the black label & flame motif were tested by someone going by the name of Lermite when they came out. The information was posted in a thread for a completely different battery over on DX. They demonstrated capacity as rated and didn't have a problem supplying up to 5 amps. I haven't asked 5A of mine, but they don't even break a sweat at 3A.
Andi's report up above is kind of worrisome, though. These are my favorite $5 cells.
fonzeka
fonzeka's picture
Last seen: 2 years 8 months ago
My first post here so hi everybody Smile
Tested my manafont dropin today with a 20A bench power supply and here's a picture of the result after a few seconds
manafont xml dropin on high
At the same voltage as above I got 991mA on medium and 171mA on low. At 3.8V the readings were 2.85A, 780mA and 129mA.
brted
brted's picture
Wow, 4.8 amps. Hope you didn't do that for very long. I wonder if people will see their clicky switches failing. A lot of those are only good up to 3 amps.
Welcome to BLF, fonzeka! Anyone with two Flukes and bench power supply is welcome here. Hope your drop-in lasts long enough for you to enjoy it!
Match
Match's picture
Welcome Fonzeka.  Nice test set-up.  I'd show a pic of my bench power supply, but the hamster is sleeping 8)
arenat
Last seen: 3 years 7 months ago
Welcolme fonzeca, that current for those emitters could ruin them permanently. I know because I ruin one with a brief  test at 5A...only notice it because that were under close look wired and such...after that test the previous flux was never reached again. However still give a lot of light only problem is that I know his dirty secretLaughing
Also when the cells are under load the voltage can't be 4,2V as the power supply show, I did a quick test and a cell measuring 4.08 V open circuit go to 3.8V under a load of 1.6A ...
fishinfool
fishinfool's picture
Last seen: 3 years 6 months ago
Aloha and welcome to BLF fonzeka!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
pipopopo
[/quote]
[/quote]
Beer is well deserved! thanks!
I have a XM-L T5 that I cannot get beyond the 3.4A on one 18650 battery (DD)
fonzeka
fonzeka's picture
Thanks guys and yes I wont be trying that again. With a fresh battery I also get around 3.4A due to the voltage sag.
It's really more than enough but I think it's perfect as a short term show off mode Smile
Budgeteer
Budgeteer's picture
Im using hi-max myself. Smile
xP.1337
yea i would say not all KD XM-L drop ins are the same
best i could pull from the KD drop in i bought off another member was 1.6 amps high.
this was off a 4.2V fully charged trustfire (flame). one that was tested to produce 2.6-2.8 amps on the shiningbeam drivers no problem.
i do not like these trustfire batteries as much as most people. problem is i dont have the money to replace mine yet. after reading tests im gonna try the tenergy ones.
jacktheclipper
jacktheclipper's picture
Last seen: 31 min 49 sec ago
I ordered the Manafont dropin back in Nov. I have been using it for a while now in a Solarforce L2 . When I first got the dropin I was using an old 18650 and I wasn't at all happy with the output or tint . I then ordered a Solarforce 18650 and when I tried that new battery - WOW - NOW THAT'S WHAT I'M TALKIN' ABOUT !
The tint and beam are MUCH improved and the light is perfect for my bike in medium mode .
All that being said , I just ordered an OP reflector for the dropin because I just can't get used to the shallow donut hole in the SMO beam . I think that the OP reflector will be the final touch to make this light great .
What I do
