OK Boaz does his first ever mod ...A light I bought almost tailstands but not really .. one of those leaning tower of Pisa lights ...
scratch head , scratch tail... huh ??..
#1 Pull out switch .. unscrew it and take out the rubber booty ..
Scratch head ...stare ..scratch tail...huh ?
#2 find small rubber washer or o ring , drop it in the tail shove rubber booty against it , screw down switch and ...
Voila...
switch is now 1/16th further into the light and guess what ????
Light now tailstands like it was supposed to ..
crazy ?? yeah .. Crazy like a fox .
... Don't even think about asking me for photos . just do it ..
υμεις εστε το φως του κοσμου ου δυναται πολις κρυβηναι επανω ορους κειμενη
Dc-fix diffuser film >… http://budgetlightforum.com/node/42208
There's an engineering solution for every problem. I like it!
or do what i do, cut the some of the rubber off the switch cap. if you look at most flashlights rubber button, theres a piece in the middle that touches the switch, if you cut that, sometimes it solves the problem
SOMETIMES. depends on the switch shape lol
I tried changing the shape of the booty by heating and subsequently freezing it , stretching it ,bending it ,cussing at it ,hoping things might change , talking nicely to it ,microwave , ice , freezer a sharp stick and then I used that puzzled look ....that didn't help much either . i can't tell you exactly what the piece was whether it was a plumbing washer or where it came from ......but it's rubbery and roundish and it fit,and it works ..Bingo .. i tried to fix something ... didn't break anything..,or make it worse ... Presto... Now my L2 N-light tailstands .... priceless
