Is this a thrower? We have a bunch of good triple floods available. Im interested if someone can actually make a top notch thrower and start sending some lumens down field..
If TK70 is around 100kcd and this has similar head dimensions (+ might be driven harder, hope so), it will throw. Better than my de-domed FF STL-V6, which can be considered as a good thrower.
Just take it that it has a TK70 head with U2 XM-Ls.
Ric just told me that the driver is a DRY driver, the one with the higher PWM (is it 750Hz or 1kHz?).
So definitely if we are basing on TK70 specs, this would definitely be way past 100k cd. (there are other things like lens, reflector quality, heatsinking….but my guess is that it is still very good and won’t affect much)
Internally there would be some minute difference, of course.
I don’t have photo of my TK70 right now, but I just measured mine it’s exactly 103.6mm across (bezel), 90.5mm reflector, and 38mm tube for the D cells (Where the two side switches are immediately located).
