[TEASER] New interesting triple U2 high lumens high lux by cnqualitygoods
the one in the description cnqualitygoods, but its not there yet
Here's my estimate: 110mm (±5mm), based on this:
and this:
Is this a thrower? We have a bunch of good triple floods available. Im interested if someone can actually make a top notch thrower and start sending some lumens down field..
Can i get an Amen?
Well.. We have to define "thrower"..
If TK70 is around 100kcd and this has similar head dimensions (+ might be driven harder, hope so), it will throw. Better than my de-domed FF STL-V6, which can be considered as a good thrower.
Oh, that makes sense.
By my calculations 103.6 mm or 10.36 cm. :D
Yep, that was exactly what I was going to do_the-. I
Looks to be an exact copy of the TK70 head. Love it!
Nice find 2100.
Looking forward to seeing it in action
The exact opposite of a flood light? Apex vs O’light SR90 - Flood opposed to a pure thrower
Just take it that it has a TK70 head with U2 XM-Ls.
Ric just told me that the driver is a DRY driver, the one with the higher PWM (is it 750Hz or 1kHz?).
So definitely if we are basing on TK70 specs, this would definitely be way past 100k cd. (there are other things like lens, reflector quality, heatsinking….but my guess is that it is still very good and won’t affect much)
Internally there would be some minute difference, of course.
There’s no point in the big optics if it’s meant to be a flooder.
But it isn't meant to be a flooder...
Me likey.
Anyone own or have good pics of a TK70 in particular the head?
I know ILF has a TK70.
I don’t have photo of my TK70 right now, but I just measured mine it’s exactly 103.6mm across (bezel), 90.5mm reflector, and 38mm tube for the D cells (Where the two side switches are immediately located).
So it's confirmed that this one has the same bezel diameter. :D My calculations said it was 103.6 mm so that is pretty close.
Ok, I know what I I’m getting next :slight_smile:
Of course there is that one with the laser….
Looking at the initial photos, it ‘seem’ to look like the reflectors are not as deep as in the original 70, or it’s maybe because the camera cannot capture the real ‘depth’ perhaps? Nevertheless, it this light can at least equal the performance, if not surpass, the TK70, then it’s a real gem, considering it’s a sawed-off shotgun version!
I agree.
If it will do this at 350yds, then it will be a super light if the price is around $120 or so.
Fenix TK70
