Mechanically/dimensionally 3x26650=4xC-size,
but if the driver doesn’t support the low voltage of 4x NiMH it might not work.
But it’s confirmed for TR-J12.
I also tried it on a TR-J18 that I have, but current draw with 4xC-size was a lot lower (only ~2A)
so with that one it doesn’t work as well.
Should be receiving a 9x XM-L soon, will see how that fares with NiMH
I had the “777” Smallsun.
It threw pretty well and was as bright as you would expect.
I think it was not regulated or something, since it faded pretty fast with Alkalines…
How does the UF 7t6 compare to the J12 or J18? Kind of interesting it’s not called the 6t6 given it has 6 emitters (even though product description says 7…).
So, would you say it’s better/worse build/tint compared to the trustfires? Thinking of getting a super-flooder and would appreciate some comments, thanks.
WOW! I have ALWAYS liked the feel of C cell Mags. This one looks REALLY interesting. I also saw that, for another $9, you can get a tube for it that will fit 2x18650. So if you have both types of batteries, this might be a REALLY good way to go! You could use C cells if you want runtime or a light that can double as a weapon. Or, if you want something smaller, switch to 2x18650. Either way, another nice thing about this light is that you don’t have to worry about failing battery holders.
