Small Sun ZY-T08
Hmm, hard to determine the tint bin for me, what I see, it’s cool white, cooler side of the tint bin, the spill with slight purple tint, the spot is pure white
You can clearly see the tint difference between the T08 vs the T13 in post #7. Like I said it’s a cooler white.
viffer750, what was the drive current on high before the mod? Also, is that a 20mm driver board? And how is the pill? Is it hollow? Good heatsinking?
-Garry
Great mod, Viffer! Thanks for sharing. Any chance we can get a mouse over comparing pre-mod beam to post-mod beam?
2.3-2.4A,
the star is bigger than 20mm, I don’t know exactly, I don’t want to take apart the head, now it is perfectly centered. :wink:
I think it is 25mm.
The pill is not hollow, and the heatsinking is very good.
I have to remove the resistor, you give me a lot of work. :slight_smile: I will try.
Sounds great! And definitely sounds like it needs the mod! So it must not be the typical "direct drive on high" type of drivers we've been seeing used a lot lately.
I realize now the driver board must be really wide due to the two battery cells needing to make contact with the center contact on the board. Is there room under the stock driver board if someone wanted to add a Nanjg driver (say one beefed up with 10xAMC's for 3.5A) and still use the stock board for battery contact only?
-Garry
Dang it viffer750! Just when I was trying to resist buying this one (actually resisting for now and post-poning the purchase another month or so)! Argh!
-Garry
Don’t bother then. I was just hoping you might have taken a pic before the change.
Hey, off the top of your head, do you recall the resistor needed to bump the ZY-T13 to the same 3.2A as this one? I know you used a pot and not a resistor but what resistor would I need instead of a pot?
I can’t wait until mine shows up!!! :bigsmile:
Can't really use the same current, T13 runs on 2series, this one 2p.
But the pot used was set to 0.7ohm to get ~1.6A, which being 2s is about equivalent to 3.2A in 2p assuming similar efficiency. So any 0.7ohm resistor will work.
I have ready stock of 0.47ohm and am itching to put it in my T13, but afraid it might just give too much current.
Just ordered from manafont. How is this light
compared to hd2010? The waiting begins. J)
I’ll let you know once mine comes in. My HD2010 just came in today and I love it! Its about equal to my UniqueFire UF-V6. HD is slightly brighter… only noticeable against a wall shot. The UF-V6 has tighter hotspot (1/3 of hd2010), and less spill. A couple more weeks, and I’ll see how it compares.
CR123’s?
Yeah I’ve had the HD for about a month and love it.
As a sanity test for your runtime graph which seems flat across entire lithium range, can you see if 1 cell has exact same output as 2? Or even better, it is possible to test boost capability with 2 AAs (directly with DMM)?
With 1 cell: yes, if the cell is good enough with low internal resistance. Probably the driver will not hold the constant current over the whole liion range, but in the first part of the discharge phase it will be regulated.
It will not work with 2 AAs surely, it’s not a boost driver.
Ok, I've been pondering this light for weeks, as it looks like it will make a great bike light. Decided to take the plunge today, have it in my Shopping Cart and want to add the extra $2 for registered air mail upgrade. I cannot for the life of me figure out how to add it - anyone here know?
If you are talking about manafont, then there already is registered shipping included. (for orders over $20)
edit:I actually tried to avoid registered shipping while ordering a ZY-T13 (i try not to cumbersome the mailman more than necessary) but couldn’t.
I placed an order for 2 lights half a day ago and they have already shipped. :slight_smile:
Ahhh. Thank you Johm - I'll order away.
