I understand where you’re coming from with your argument, although your argument that increasing the depth of an ideal reflector reduces throw does not necessarily agree with the logic that let you conceive your ideal reflector [see (1) below]. But I believe you’re onto something.
However unreasonable it would be in real life, consider a reflector with a fixed diameter and infinitely adjustable depth. Assume it’s made from shape-shifting metal like the T1000 from Terminator 2 :cowboy_hat_face: .
Ignore the Inverse Square Law for a minute, and consider the ramifications of significantly increasing the reflector’s depth. This is not the same as changing the equation of the parabola; you are rendering the equation so the vertex [focal point] remains on the x-axis as you ‘stretch’ the ‘wide end’ of the reflector toward +∞ [see (2)]. The resulting beam from this reflector becomes closer to perfectly collimated as you approach the point when Depth/Diameter ≈ Depth/1. A white-wall shot would reveal the beam has uniform intensity, with no hotspot, corona, or spill.
(1) Our flashlights have reflectors small enough with emitters bright enough that we can essentially ignore the Inverse Square Law for our purposes [if reflectors have equal diameters, slightly different depths, and identical LEDs]. The ISL describes the relationship between light intensity and distance [Lux decreases exponentially with distance]. Thus, it’s imperative for any difference in distance that light has to travel [differences between reflectors of various depths and identical diameter] is kept “reasonably small” when drawing conclusions.
We can make these assumptions because the differences in depth between our various flashlight reflectors is tiny, or reasonably small compared to the distances our lights typically throw. There are other reasons, but that is probably the most pertinent and encompassing. These logical assumptions let you conclude that under most circumstances involving flashlights, a deeper reflector shouldn’t directly influence peak hotspot intensity compared to a shallower one. Unless the shallow reflector is too shallow too begin with…but that’s a special case.
(2) Analogous to plotting y(x)= x2 on a graphing calculator, and then zooming out so far that you can see x=∞ and y=∞ (obviously, not realistic but you can ascertain the significance in theory)
I’m just musing here, I’m no expert. So feel free to bash and put a dunce cap on me if I’m wrong :party:
The bottom line with throw is diameter and emitter (surface brightness).
If you want more corona, which won’t increase throw but may be useful (depending on your purposes) then go for a deeper reflector as well. This may be useful at intermediate distances.
If you want still more throw then replace the reflector with an aspheric lens. You’ll have no spill and a hotspot shaped like the emitter but it will throw further.
The greater the diameter the smaller and brighter the hotspot and therefore the greater the throw.
If you want a larger hotspot use a larger emitter (XL-M). If you want the greater surface brightness (throw) use XR-E or something similar.
That’s more or less all the factors other than driving the emitter as hard as is productive.
Keep in mind that the inverse squared law is the one that applies to throw so gains in lux have to be large to make much of a difference in reality.
Explanations given in these forums were thusfar always too unclear to me (and often not true), but, thanks to this thread, for the first time i get an actual grip on why xre-leds are, with their narrower radiation angle, so good in throw compared to newer leds
Uhm, actually XR-E’s narrower emission angle doesn’t help for throw, it’s just their higher luminance, or simpler put, their higher emitted lumens per square millimeter ratio.
Veeery interesting experiment, DJ I knew that for better throw you need a bigger reflector, but I didn’t know that the throwy part came from outer part of the reflector Spill depends on central part.
Could be very useful if you want to stipple your reflector. You can cover the outer part of the reflector with something and stipple only the inner part - you will maintain good throw but will get smoother spill
The curvature of the parabola can of course be defined mathematically, but a better way to visualize the geometry is via the conic section: http://math2.org/math/algebra/conics.htm
Since you can make a cone arbitrarily “fat” or extended, it’s easy to see there’s no restriction on dimensions.
Did you ever get a chance to look at why dedoming significantly increases throw? If anything it should be extracting more light from the high RI emitter. It makes no sense to me.
The shape is still parabolic. The key distinction to note here is that the telescope is built for rectilinear imaging (and thus relatively uniform magnification) whereas the parabola reflector is not. IThe hole experiment is supposed to show that the focal length (and by extension magnification) changes significantly towards the edge.
Surface brightness is the great claim to fame of the xre, but also; regarding that the outer part of a reflector contributes more to the center of the hotspot than the inner part, I suppose it helps that the xre-beam is narrower and thus makes less use of the inner part (bigger portion of the light in center of hotspot, less corona around it)
well, being a (convinced) biologist I settle for: experiments are fun
True, there are no restrictions on dimensions in general because all sorts of ratios provide different/diverse/interesting properties.
But to produce maximum throw, as this thread inquires, i find it a little hard to accept how there can be more then one ideal depth (given width).
Can more than on parabola shape (only depth to vary) be found that focuses a point to infinity?
A reflector for throw should only have spill and hotspot (as small as possible).
By making a reflector ‘shallow’, you let more light become spill, also light hitting the reflector will not bounce at the ideal angle to become ‘center hotspot’ producing large hotspot and flood.
By making a reflector ‘deep’, the light is again not bouncing at the ideal angle to become ‘center hotspot’ and produces larger hotspot and flood. What comes to compansate here is spill is less, spill moves to food and larger hotspot but not enough to compensate for the loss of ‘center hotspot’ thus throw.
That’s the conclusion I’ve come to. The JM05 clone I have is the same diameter compared with my Ultrafire C8, but much deeper.
It produces a much tighter hotspot, and also a much larger brighter corona, and although the hotspot is tighter it doesn’t seem as bright as the larger ultrafire C8, so I’m assuming Lumens are lost on the larger corona, and not really making any or little difference to throw.
Handy beam pattern though, it does give it more flood with the corona, without loosing any throw, albeit a tighter hotspot (with less lumens).
One more thing to ask, we are talking reflector size diameter vs depth, but we are not taking in account the different curvature of the reflector.
Let me explain better, some reflector looks like the are almost half parabola, instead some other looks like a smaller section of a bigger parabola, even if the sizes are similar.
Or by converse two reflector may have different size, but be different portions of the same parabola, eg with the same curvature.
Agenthex “A parabola by definition focuses a point to infinity.”
You can capture more light with a deeper reflector, but you can’t necessarily project it at any arbitrarily small angle of departure.”
YES!
However this is only true for a “point source of light” In the real world an LED only approximates a point source. The parts of the dome that are not exactly central would be out of focus, so those beams of light would not project parallel to the rest of the beam. It is because of the “out of focus” effect that XR-E LEDs make better throwers than XM-Ls. Even though there is less lumens, the smaller die size of the XR-E more closely approximates a true point source of light.
Mathematically, a perfect point source of light placed exactly at he foci of a perfect parabolic reflector would emit a “laser like” beam of focused light.
What you folks are failing to understand is that the XR-E has a narrower viewing angle and that puts more light into the beam than a like emitter putting out the same amount of lumens but with a wider viewing angle. Take an XR-E R2 and an XP-E R3 and drive them both to 200 lumens and you’ll see that the bright portion of the light has a higher lux reading on the XR-E without a reflector. Put a reflector over that emitter and what light bounces off of it is of a higher intensity than if you placed that same reflector over the XP-E even though the XP-E uses more of the reflective surface. As shown above, that extra surface will mostly contribute to the corona.
SashiX & djozz:
No, actually all parts of the reflector (that are hit by the LED light) contribute equally to throw. Take a flashlight (off!) hold it at arm’s length and point it towards you. See the yellow area? All that is the effectively used apparent reflector area I’m talking about. Luminous intensity is directly proportional to that area (inner and outer parts of it). In that nice experiment the light from the inner part seems to be all spill, but that’s wrong: spill is light that doesn’t hit the reflector at all. In both pictures you get spot and spill, but in the third picture it’s outside the picture (a small part of it can be seen in the top right corner). In the second image you see the (bigger) spot from the reflector and spill around it. It’s not as bright as the spot in the right picture since the area is smaller (and maybe the ‘dead hole’ additionally reduces the effectively used area, too).
Actually the narrower XR-E angle (and by that I mean the hard limit at about ± 60° due to that metal ring) reduces throw because it makes a bigger dead hole. That’s where the deep reflectors gain some % because they have a smaller hole.
Rockspider: You drew ellipses, not parabolas. There is no way to draw two different parabolas like you did with the two ellipses to the right.
dchomak: No, it’s only the XR-E’s superior lumen density (actually luminance). That die with a different dome would throw equally (or actually a tad better).
PCC: The smaller beam angle of the XR-E works as a pre-collimator, thus the bare XR-E throws better than an otherwise equivalent XP-E. However that does NOT increase throw when using another lens or reflector to go the rest of the way to maximum collimation. XR-E's dome does not increase luminance and thus does not increase throw.
@ Dr. Jones: A few questions if I may also join this interesting Q&A thread :-)
If I understand this correctly a XP-E positioned at the same focal point in the same reflector as a XR-E should throw better due to wider beam angle that makes more light hit the reflector, right? (if lumen output of the two are equal => same drive current)
The de-doming adds to throw because
A) The apparent size (The size the reflector "sees") of the phosphorus layer becomes smaller when the led dome is removed because the led dome magnifies the phosphorous layer, right?
B) The beam angle goes from being more concentrated towards the center of the beam by the optical properties of the dome (50% of the XML intensity within the 135° of the beam if my memory serves me right) to being nearly evenly distributed in a very very wide angle (nearly 180° by the looks of it) and thus far more light hits the reflector and enters the hotspot portion of the beam. E.G the part of the beam that is "focused on infinity" because the reflector is "focused on infinity" ?
PS. Sorry if the above is difficult to read, I typed it as I thought it and my thoughts are not always linear. And TY in advance to any clarity you can add to my understanding of the matter at hand.
