Yes, I can do that with a reprogram. That will be a extra option. I have had several people ask the same thing. If I have a enough demand I will not charge a reprogram fee. I still need to program a light and make sure that option works good.
Basically the same but different pinouts on the micro. BLM designer will work if you want to play with your own settings. I have my “own” BLM designer for this light. It uses different firmware.
$300 for one, $575 for two and $825 for three for the first 60 lights as A introductory price. After that they will be $325 for one $600 for two, $900 for three.
Vanquish chassis, Traxxas bigbore shocks, Mini-t springs, Titanium lower links, Holmes 35T hand wound motor, Tekin FXR ESC, CC bec at 7.4V, Hitec 7954hs servo, AX10 metal gear transmission, Overdrive gears front, Underdrive gears rear. I am not competing yet but I will after I get these lights moving. I have several friends that are already competing in Sportsman and 2.2S.
