Yes, I can do that with a reprogram. That will be a extra option. I have had several people ask the same thing. If I have a enough demand I will not charge a reprogram fee. I still need to program a light and make sure that option works good.
Basically the same but different pinouts on the micro. BLM designer will work if you want to play with your own settings. I have my “own” BLM designer for this light. It uses different firmware.
$300 for one, $575 for two and $825 for three for the first 60 lights as A introductory price. After that they will be $325 for one $600 for two, $900 for three.
Vanquish chassis, Traxxas bigbore shocks, Mini-t springs, Titanium lower links, Holmes 35T hand wound motor, Tekin FXR ESC, CC bec at 7.4V, Hitec 7954hs servo, AX10 metal gear transmission, Overdrive gears front, Underdrive gears rear. I am not competing yet but I will after I get these lights moving. I have several friends that are already competing in Sportsman and 2.2S.
Looks like the big producers of light bars have started to use XM-L as well now.
Take a look (for curiosity) at Vision-X Prime Drive Bars (just google it)
Theirs appears to have much less dissipation surface, at least this is what it looks like by eye. If so, their driver will dim the output to avoid overheating.
In the explanations they say the driver works in PWM, but it's not clear what frequency. I suppose high enough to not result in strobo-vision though.
By comparison Your bar looks better and stronger!
Also, even if I'm not happy to admit (because it's still a remarkable amount of money, LOL!), when comparing their price for the same size 6 led bar, your is cheaper
